Old 08-17-2010, 03:42 PM   #1
1981 31' Excella II
Longview , Texas
Images: 14
Replace or Repair gray water tank??
I haven't removed the gray tank yet but I suspect that we either have a leak in the tank or possible in the pvc. In anticipation of the tank having a crack in it I've called Airstream and they tell me that I can't get a new tank for my '81 Excella II TT. Has any replaced a gray tank for this model and if so, where and what did you find to replace the old one?
Also, wondering if it's possible to simply repair the tank if it's cracked - assuming that the crack is not too bad? I recently purchased some Eternabond roof sealer tape and it seems like the specs said that it was suitable to water tank repair. Anyone have any experience with this?
I'm waiting on Inland RV to call me back about whether or not they can find a replacement tank in case I need one.
Thanks in advance for any advice!!
boo_n_sue is offline   Reply With Quote
Old 08-17-2010, 05:31 PM   #2
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Go to an automotive place and get a repair kit for a plastic rad tank. They work real good on the trailer tanks.
http://www.permatex.com/products/aut...Repair_Kit.htm
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Gray water Tank CJ of Okla Waste Systems, Tanks & Totes 10 08-09-2008 10:01 PM
Gray water tank? cookeville34 Waste Systems, Tanks & Totes 5 11-19-2006 07:48 AM
Tank repair or replace? FreshAir Waste Systems, Tanks & Totes 13 10-10-2006 11:38 PM
Gray Water Diverted Into Black Water Tank Chaplain Kent Waste Systems, Tanks & Totes 5 06-14-2006 06:38 PM
Gray tank repair cadonnelly Waste Systems, Tanks & Totes 3 07-18-2003 11:52 AM
