Old 03-03-2008, 04:06 PM   #1
1965 20' Globetrotter
Winter Garden , Florida
Replace a Thetford Valve with a Valterra?
I have to replace the valve and sanitary tee on my 65 Globetrotter's black water tank. The existing valve is a Thetford 01447 that attaches to the bottom of the tank, followed by a Thetford tee where is gray water drain merges for the sewer hose connection. I can find a replacement for the Thetford valve, but I can't seem to find the Thetford tee. I can find a Valterra tee, but I am concerned the tee won't mate to the replacement Thetford valve. If I change the valve to a Valterra, will the Valterra connect to the tank the same as the Thetford? Or can I just get a valterra tee that will mate to the theford valve? Any insights are appreciated.
I am attempted to include a picture of the valve and tee in question.
Thanks!
thunder433 is offline   Reply With Quote
Old 03-03-2008, 04:36 PM   #2
Thanks!
The "T" is called a collector.
It has not been available for years.
We have developed a method to repair them to be as good as new.
The cost depends on the condition.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 03-03-2008, 04:41 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
You may be best to just let Inland repair it. But, here are a couple places that have been around for a long time in Columbus - sometimes you can get lucky with stuff they have in old dusty inventory. Good luck.
POST'S*TRAVELAND*::*YOUR*RV*SOLUTION
Jerry Greer RV & Toyota Marine Sports 800 424 8289
6700 E. State Route 37
SunburyOH43074-9215
Valterra to Thetford connection Craig Waste Systems, Tanks & Totes 30 03-05-2011 07:49 PM
Only one Thetford Valve? The Flintstones Waste Systems, Tanks & Totes 10 10-09-2006 08:53 PM
Thetford Valve garyphelps Sinks, Showers & Toilets 1 08-27-2006 07:54 PM
Rebuild or replace old Thetford dump valve? 63air Waste Systems, Tanks & Totes 7 05-21-2006 02:47 AM
Thetford vs Valterra pilgrim_still Waste Systems, Tanks & Totes 8 06-11-2005 01:34 PM
