Old 02-21-2011, 08:57 AM   #1
theodore , Alabama
repair question
repair question
HI! My name is randy and I have a repair question on my airstream.
judran2 is offline   Reply With Quote
Old 02-21-2011, 09:05 AM   #2
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Welcome and go ahead and ask.
Dave
Old 02-21-2011, 09:11 AM   #3
theodore , Alabama
Thanks DaveI live in my airstream for now. But, where u put city water in is good.
But . behind the front side behind the three tires water it dripping out a tube and costing a lot in water. So why is water coming out this tube???
Old 02-21-2011, 09:19 AM   #4
masseyfarm's Avatar
Images: 56
Did this just start after the cold weather????
I'm not familiar with your trailer model, but it sounds like the line is cracked or a fitting is loose.
You have detailed the model and year your trailer is so those with the same type may be able to help you.
Dave
Old 02-21-2011, 09:25 AM   #5
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Is the tube one of the drain lines?
Airstream water systems have drains installed so one can drain the system for winter storage. If that's what you're dealing with, it should have a valve nearby that will close off that tube. Look "upstream" of the leak along that tube.
Airstream water lines are installed above the floor, so they're usually easy to inspect.
If you have an owner's manual, the system should be explained in that. If not, Airstream should be able to supply you one for a year model that recent. Their factory website is a good one. I've had good luck with their customer support people, although our unit is much older.
Old 02-21-2011, 09:53 AM   #6
theodore , Alabama
repairing water problem
is someone here to help me???
Old 02-21-2011, 09:58 AM   #7
masseyfarm's Avatar
Images: 56
Look here for some suggestions.
http://www.airforums.com/forums/f163...hen-62716.html
Old 02-21-2011, 09:59 AM   #8
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
We all need help. Problem and pics would be helpfull.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 02-21-2011, 10:10 AM   #9
theodore , Alabama
water problems
water coming out small tube behind tires and running up my water bill how do i fix
Old 02-21-2011, 10:14 AM   #10
HowieE's Avatar
Princeton , New Jersey
Images: 12
Yes, but we need to know what the problem is.
2004 Excursion 4x4
Old 02-21-2011, 10:14 AM   #11
Are you talking about the drain for the AC?
Old 02-21-2011, 10:20 AM   #12
x
XXXX , XXXX
OMG he has posted in several sections expecting live chat help. The OP needs to slow down and understand the nature of the forum.
wasagachris is offline   Reply With Quote
Old 02-21-2011, 10:33 AM   #13
Kevin245's Avatar
judran2,
We moved your posts into this one thread.
Please elaborate on the problem you're encountering and see if the members can help you out.
Kevin
Eleanor Roosevelt
Old 02-21-2011, 10:37 AM   #14
HowieE's Avatar
Images: 12
Open the front closet door and lift the closet floor. In the front left corner you should find a hole down through the subfloor. There are 2 drain valves below the floor. Before you attempt anything see if you can reach down through the hole or crawl under the trailer to see if water is dripping from either of these valves. If it is one of the valves they are 1/4 turn while pulling on the valve stem to open and 1/4 turn while pushing on the valve to close. They are not easy to work and hard to get at so be sure that is the problem before you do anything with them.
Under the trailer behind the center passenger side tire is the drain for the fresh water tank. Check that valve for leaking.
Under the floor of the closet is the Auto Fill Valve. Open the center closet door, you may have to lift the heater tube, you will see a 1/4 in. copper line coming and electric solenoid off the plastic water lines. The switch for this system is on the control panel. If the solenoid leaks or was left on that would have filled the fresh water tank and with city pressure may have cracked something.
2004 Excursion 4x4
water leak/drip
LP regulator question GAT LP Gas, Piping, Tanks & Regulators 17 05-09-2011 07:09 AM
EVAP Canister? question 8rmesse Classic Motorhomes 23 04-24-2011 06:41 AM
Pacific Northwest Repair or Restoration TGK General Repair Forum 11 03-30-2011 12:24 AM
A 'SMART' question.... FreshAir On The Road... 10 02-06-2011 09:00 PM
Trailering Question Cracker Jacks, Stabilizers, Lifting and Leveling 14 01-02-2011 02:55 PM
