Old 03-11-2015, 09:12 PM   #1
2Rhinos's Avatar
1974 27' Overlander
1970 27' Overlander
Houston , Texas
Images: 18
Repair or Replace
Need some opinions.
'74 Overlander auxiliary (gray) tank has crack/leak.
Repair or replace.
Doing a complet shell off restoration.
ID:	234037   Click image for larger version
2Rhinos is offline   Reply With Quote
Old 03-11-2015, 09:17 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Epoxy and glass tape it.
MICHAEL
Old 03-11-2015, 09:20 PM   #3
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Replace it. Upgrade to bigger tanks.
Lance
Top is offline   Reply With Quote
Old 03-12-2015, 09:35 AM   #4
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Your tanks look like they are made of polyethylene, in which case you will have a really hard time finding any kind of adhesive that will stick to them permanently. You might find someone with the capability to do plastic welding that might successfully repair a crack, but I expect that if the tank is cracking in one place, another crack is not far behind.
You might want to replace that grey tank anyway, just for the sake of getting something larger. Vintage Trailer Supply now offers grey tanks that are specifically sized to fit in the frame compartments of 70's trailers.
good luck!
Old 03-12-2015, 09:53 AM   #5
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I swear by J B Weld. Regarding the water tank, same material I had cracks in the drain line connection and the line connection to the water pump, double coat of J B Weld, DONE! Worked great!
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 03-12-2015, 01:37 PM   #6
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Since it's already out, suck up the cost and replace. You don't want to have to pull it apart again a year or two from now to fix another crack.
Silverflames is offline   Reply With Quote
Old 03-12-2015, 03:51 PM   #7
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
After all the time and money you are investing in your restoration, why go cheap on the holding tanks? Even if you did manage to fix the existing cracks, it's still going to be an old piece of plastic a long way down it's a finite life.
Bob Martel
WBCCI# 5766
To Replace or Not to Replace 65air Towing, Tow Vehicles & Hitches 3 03-29-2013 12:58 PM
2 replace decal or not to replace? nustreamer Clearcoat, Exterior Paint & Trim 1 07-15-2011 10:28 PM
To replace or not to replace the axles airstrmkids Axles 17 01-13-2011 06:20 AM
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 03:51 PM
Sink...Repair or Replace?? COArgosy78 Sinks, Showers & Toilets 17 08-05-2003 03:28 PM
