Old 10-11-2016, 06:11 PM   #1
Larry C's Avatar
1996 34' Excella
Elberta , Alabama
Removing black and grey water valves on '96 34'
Guys, I need some advice, I have a broken (cracked) Thetford valve on the black water tank. My repair guy said it would be major to remove the valve, as it's glued into the black water tank.
If it is glued in, why is there a heavy duty clamp where the valve body connects to the tank. It looks to me if the clamp is removed, on both the black and grey water tanks, after the valves are taken apart the entire plumbing should come out, and the valve bodies, connected to the tank should be able to be removed.....
I've done a lot of stuff to Airstreams, but this is a new one for me....advice is welcome....
Larry
Old age is coming at a really bad time!
1996 34' Excella 1000, interior totally redone, 2003 Dodge/Cummins HO, U.S. Gear exhaust brake, Diablo tuner, 115 gallon aux fuel, Bedslide, Airsafe/Reese Dual Cam, and a bunch of other stuff
Larry C is offline   Reply With Quote
Old 10-11-2016, 06:39 PM   #2
CRH
1995 25' Excella
xxxxx , xxxxxx
My 1995 was not glued in. The large clamp holds the valve to tank adapter inside the tank neck.
The plumbing after my valves has a rubber connector holding the the black and gray Ys together to create the dump manifold.....taking that connector loose made removing and replacing the valves easy.
I replaced both of my valves last summer. The job was fairly straight forward. I bought new valves and tank adapters. I bought the plumbing pipe at the big box hardware store.
CRH is offline   Reply With Quote
Old 10-11-2016, 07:40 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
My trailer is ten years older than yours, and quite possibly built differently. My dump valve manifold was not glued to the tanks. However, there was what I call white "butyl caulk" between the molded tank drain and the ABS piping. Mine has a hose clamp around it.
David
Name:	1205 Gray Water Tank Discharge Hole.jpg
ID:	273427   Click image for larger version
Name:	1205 New Valtera Gray Tank Valve.jpg
Name:	1205 New Valtera Plumbing.jpg
Old 10-11-2016, 09:50 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
My '74 Argosy has the same setup as your '96. I doubt it is glued. Just a hose clamp. Unless your tank is ABS I doubt there is any glue that would bond the sewer pipe and the tank fitting.
Old 10-11-2016, 10:59 PM   #5
1991 25' Excella
Hartford , Wisconsin
I did the valves and piping this past summer here the link to my posts on yhe subject
http://www.airforums.com/forums/f444...-a-153935.html
TOPORANGER is offline   Reply With Quote
How to Protect Black and Grey Water Valves aap Waste Systems, Tanks & Totes 2 09-08-2016 08:23 PM
Black and Grey Tank Valves Hard to Pull Ssmookler Plumbing - Systems & Fixtures 2 03-08-2015 04:22 PM
Minuet Water Valves - What is What? Grey and Black ply5013 Waste Systems, Tanks & Totes 1 11-16-2012 11:04 AM
Black/Grey Water Valves - Drama on the road!!! AndyPenny Waste Systems, Tanks & Totes 1 07-19-2008 11:03 PM
'78 20' Minuet repair question: grey/black water drain valves Van All Argosy Trailers 4 01-06-2004 09:40 AM
