Old 11-10-2017, 01:21 PM   #1
1957 22' Flying Cloud
seattle , Washington
Remove 1957 blackwater tank
Looking for advice on removal. Does the bottom pan need to come out to remove this tank? The tank is in the on top of the sub floor but is not coming out although it is generally lose.
thanks,
Mike
youngmg69 is offline   Reply With Quote
Old 11-28-2017, 05:23 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
You'll need to make sure the tank is disconnected under the trailer. The belly pan should have a removable area around the valve. You'll need to unbolt the valve from the bottom of the tank. It MIGHT have small bolts in the corners, or may have been updated to a 3" pipe fitting, who knows. Once that valve and any T's or Y's are disconnected the tank should lift out from above.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
Wally Byam's 1955 26' European Caravan Trailer!
goransons is offline   Reply With Quote
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
grey watertank and blackwater tank herdsman Waste Systems, Tanks & Totes 7 02-14-2006 03:58 PM
Blackwater tank flush inlet jordandvm Waste Systems, Tanks & Totes 2 10-26-2004 05:02 AM
Bypassing Blackwater Tank westeagle Waste Systems, Tanks & Totes 3 03-19-2004 06:35 PM
'52 blackwater tank Cruiser Waste Systems, Tanks & Totes 1 09-01-2003 08:28 PM
