Old 05-07-2012, 09:11 AM   #1
Lfemat's Avatar
2004 25' International CCD
Mexico City , MX
Reconnecting black water tank
Hello all,
Im trying to re connect the wires in the black water tank in my 1970 Safari.
There are 3 terminals and 3 wires that i assume have to get connected on some way. I have tried all the combinations between them with no success. Im posting a picture of the terminals and the cable im referring to.
Any help or a picture on how is supposed to be wired?
Thanx.
Lfemat is offline   Reply With Quote
Old 05-22-2012, 01:36 PM   #2
Western slope , Colorado
01 black tank wiring
Just happen to be down there replacing the tank adapter and here is what I have.
Seems to be a lt. brown to the upper terminal along with the green,
yellow to the middle, blue to the bottom. A separate white to a 4th indicator on the other side of the 3" drain.
I believe that the lt brown and the white are from the control panel in the galley..could be wrong there. the green, yellow and blue are tied together in some sort of orange sealed thingy which might be some sort of resistor or may just be used to keep the connections water tight.
hope that helps.
ID:	159019   Click image for larger version
ID:	159021   Click image for larger version
"If you come to a fork in the road, take it."
Yogi Berra
Streamside is offline   Reply With Quote
