Old 12-01-2004, 03:52 AM   #1
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Cool Rebuilding Waste valves
Is there a good resource for rebuild kits for the 3" Thetford valves? I have a section of the floor removed in my '75 Tradewind and removed the waste pipe. Now would be a good time to do Preventive Maintenance....
balrgn is offline   Reply With Quote
Old 12-01-2004, 06:32 AM   #2
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
On my 75, I just replaced the whole valve - found that to be easier.
Ken
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 12-01-2004, 06:53 AM   #3
RiskIt's Avatar
1972 25' Tradewind
Lake Worth , Florida
Send a message via AIM to RiskIt Send a message via Yahoo to RiskIt
I did the same (replace it). BUT>>>> I had to buy 4 of them to finaly get the right one. I must have explaind it wrong to one guy on the phone, and I ordered the others online looking at pictures. I haven't had time to try and return them yet. I was going to just put them on ebay along with a bunch of stuff I had left over from my rebuild. If you let me know what it looks like or better yet a picture I might be able to help you out.
RiskIt is offline   Reply With Quote
Old 12-01-2004, 07:59 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
I just bought a whole valve from a trailer place in Danvers, Ma. not tooooo far from either of you 2 s. NH people. But you can get them online almost anywhere.
which reminds me....you guys should come check out the wally club next spring....our first rally is at the Salisbury Beach state park. At least come visit, if you can't camp w/ us for the weekend. the NewEngland unit of the wbcci is "not your father's wally club". although, now that I think of it, alot of us do have our father's era airstreams. lots of vintage owners.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 12-01-2004, 09:41 AM   #5
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Cool Waste valve
I sent you A PM. If you would like to see the pics I have on the project so far:
http://home.comcast.net/~balrgn/Airs...oject_2004.htm
Old 12-01-2004, 09:43 AM   #6
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Cool Waste valve
I hate trowin away a good piece of plastic. I may go that route. Looking for options right now, while they are off the tanks.
When is the Rally??? I need to join soon eh?
Old 12-01-2004, 10:27 AM   #7
balrgn.
The plastic used to make the dump valves is reasonably stabile.
However, dimensionally, in time, it changes.
Therefore, to rebuild the valves, reinstall them, only to find that they still might leak, is a great waste of time.
If your original valves only lasted 30 some years, so will the replacements.
It is very doubtful, that dump valve repairs will last that long.
The short of it will cost a little more money.
The long of it, is peace of mind, and saving considerable time, that could be put to better use, such as having a peace of mind, "cool one."
Old 12-01-2004, 11:59 AM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
oh, there's no rush, I'm sure. I haven't got an exact date for the rally, but I assume it is sometime in May.
I didn't see any pm's from you...I hope the mechanism isn't broken.
I did check out your pics, though. I have the same issue in the bathroom. not looking forward to the fix. I'll need to replace all the way across the back.
Air:291
Wbcci: 3752
'73 Safari 23'
Old 12-01-2004, 12:29 PM   #9
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Cool Waste Valves
I am replacing 12" along the back to get the punky stuff out. Looks like the band that goes around the back outside separated and water seaps in there.
It seemes everything I take apart 2 more things need attention. Oh well, love to tinker. That's why I got this one.
Andy Has a good point. out with the old in with the new. I'd hate to have to rework anything under there. Frame rail needs to have pieces
Old 12-01-2004, 03:50 PM   #10
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I got the kit(s) from camping world for less than 25 bucks each. I redid both the valves in my MH. The new valves cost a pretty penny, and you have to cut the old ones off and solvent weld the new ones on. If you have the old off already due to misfortune or tank replacement, then I would go new IMHO, but the ones I have rebuilt have all been leak free, so far.
The valve body has a part number as part of the stamping on the valve. You need this number to be sure to get the correct kit. There are steel blade and plastic blade valves, depending on the year, or if they have been replaced in the past. This is the reason for the different kits. The valve comes apart with the removal of the 8(?) screws. The kit will contain a valve gasket to replace the one that tears as you take the halves apart, and the actual seal. The seal is pressed into the valve body by hand, but I use a wooden dowel to completely seat it in the groove. I also apply silicone to the seal after install, and to the blade, and O-ring on the handle stem. One thing to look at is if there is rust on the handle stem. The rust can cause it to bind or stick and you will not be able to get it open. I used a bit of emery paper to clean up the stems on mine and liberally siliconed them too.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 12-01-2004, 04:55 PM   #11
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Cool Valve repair
Thanks for the info. I'll look around the area for rebuild kits.
The numbers are easlily read, 01447Slide-EZ Valve D.W.V. IAMPO T-1169. No rust, and prior to removal worked fine.
Old 12-04-2004, 02:31 PM   #12
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Cool Rebuilt waste vale
I found some one local that had a new valve. Got a great deal. I removed the internals and replaced the parts. The new one was different enough that if I attempted to replace the whole body I would be into a whole new project!
gas valves gmlcjb LP Gas, Piping, Tanks & Regulators 5 07-17-2006 09:31 AM
valves for horizontal lp tanks? Oak LP Gas, Piping, Tanks & Regulators 1 10-20-2002 11:26 AM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
Valves and Valves smily Plumbing - Systems & Fixtures 5 08-22-2002 04:01 AM
Waste Water Outlet Valves Danno Waste Systems, Tanks & Totes 2 06-18-2002 10:48 AM
