Rear Floor Renewal - Add Gray Tank?
I was under the rear of the Overlander last weekend and could see up to the plywood deck only to behold a bunch of delaminated plywood. An inspection inside to what could be seen never showed the amount of damage present. So I have now ripped out the first two sections of plywood which gets me to the wheel wells. (I'm just glad I replaced the floor in the front of the coach first - sort of a warm up exercise) Now I have the option of adding some grey water storage. If I elevated the tub enough I could get a thin tank to go between the frame rails. If necessary, I could also reinforce the rails from the axles back although I would probably not tow with the grey tank full. I recall seeing a thread at some time where another owner had fitted a grey tank in this location. Any ideas, comments? I'll post a pic later.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
