Old 11-23-2013, 10:34 PM   #1
groovzilla's Avatar
1966 20' Globetrotter
Seattle , Washington
question regarding the routing of new drain pipes
all,
i have a 68 26' overlander and i am re-configuring the interior - i am designing a rear bed setup w/24x32" shower on curb side and toilet on other side with a 36" wide walkthru to get to the bed..
both the shower and toilet front of the trailer side walls will be placed right at the point the rear portion of the plastic wheel well hit the floor.
i haven't removed any of the belly pan yet to investigate the underside.
i will want to get my shower drain over to the toilet side - are there any pass thru's(openings) in the frame in this area of the frame?(about 16" from the most rear portion of the wheel well) OR, is there room between the belly pan and frame rails for the 2" drain pipe to travel?
any help appreciated
groovzilla is offline   Reply With Quote
Old 11-23-2013, 10:44 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
No holes to get you thru the frame. You have to set up so that the drain is outside the frame rails……or have the drain tubing below the belly pan.
Old 11-23-2013, 11:48 PM   #3
groovzilla's Avatar
thanks - any room if i go toward the rear with my drain and head away from the curb side once i get to the rear bumper area?
i'm in the process of removing the floor in that area so i haven't had a chance to get my eyes on it.
Old 11-24-2013, 05:59 AM   #4
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
The two main frame rails are solid and run from front to back. The cross braces between the rails do have pass throughs. The outriggers which extend approx 10" outside each rail also do. This will allow you to run lines from your drain to tank either inside the rails or outside, but the only way to cross the rails is from above your floor, or below the belly pan.
Pic of my 1970 frame, yours would be the same.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 11-24-2013, 09:58 AM   #5
groovzilla's Avatar
thanks all very much!
