Old 06-08-2004, 01:44 PM   #1
PVC Hose Storage Carrier
I want to install one of the PVC Hose Storage units under my 2004 CCD Intl.
I thought that a good place to mount it would be between the Grey, and Black water storage tanks because of the access to the frame. But, if I mount it to the frame, that removes the access to the spot dedicated for the jack.
If anyone else has mounted one, could you please let me know how you secured it to the bottom of your Airstream?
Tom
Tom
2004 22' Intl CCD
2003 Toyota Tundra SR5 (Std Cab)
Equalizer
temcotom is offline   Reply With Quote
Old 06-08-2004, 02:29 PM   #2
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
I just installed one on our 28' CCD. It's mounted behind the black water tank.
I wasn't thrilled with the 4 sheet metal screws that were included so I fashioned 2 brackets out of 1/8" X 1" aluminum stock (Ace Hardware) and attached them with the existing bolts that mount the black water tank. They are "L" shaped with a little thing on top that I drilled a 1/2" hole for mounting.
I then used some wire ties to secure the carrier to the brackets.
(I'll get a picture and post it when it quits raining )
Dennis
cosmotini is offline   Reply With Quote
Old 06-08-2004, 03:53 PM   #3
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
Here's the pic
Hope this helps!
Old 06-08-2004, 04:33 PM   #4
Definitely helps. Thanks for the picture. It does not look like you mounted it to the frame. Is it screwed into the Aluminum sheet on the bottom of the trailer?
Tom
Tom
2004 22' Intl CCD
Equalizer
Old 06-08-2004, 04:48 PM   #5
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
Correct.
The screws are just in the underbelly. That's why I built the brackets. I couldn't hit the frame where I wanted to mount the carrier.
Dennis
Old 06-08-2004, 10:50 PM   #6
jordandvm's Avatar
2017 28' International
Western , Oregon
Images: 58
So is this your fresh water tank hose storage location? What about all the road dust and grime that kicks up behind the wheels? Do you have a hose cap to keep it clean? Seems like rocks and such would be kicked up to possibly damage the reel and hose. How long is your hose? (Boy do I have a lot of questions! Can you tell I'm a Newbie? I'm always learning on these forums.... so bear with me!
Jim & Cheryl
2017 28' Signature CCD
2017 GMC Denali HD Crew Cab 4x4
Blue Ox Sway Pro Hitch
WBCCI #3538
jordandvm is offline   Reply With Quote
Old 06-08-2004, 11:09 PM   #7
dscluchfc's Avatar
1984 31' Excella
Abernathy , Texas
I think the hose being stored in the tube is the black and grey water dump hose.
dscluchfc is offline   Reply With Quote
Old 06-08-2004, 11:15 PM   #8
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
Jordandvm,
dschuchfc is correct. This holds the sewer hose. I have a 6' carrier that is long enough to keep 2 of the 10' expandable slinky hoses attached. So I have up to 20' of sewer hose available. It also isolates the hose from getting 'crap' on the stuff I keep in the rear bumper strorage area.
Old 06-09-2004, 12:05 AM   #9
jordandvm's Avatar
Western , Oregon
Images: 58
OOOOOOOOOOOOOh. Well, I've learned a new one then! My wife said I shouldn't store the Black/grey water hose in the same location as the fresh water hose (in the bumper storage)! Duuuuuuuuuh!
Jim & Cheryl
WBCCI #3538
Old 06-09-2004, 06:42 AM   #10
Cracker's Avatar
Pittsfield , Maine
The PO of my Airstream mounted the PVC storage tube forward of the axles and roughly forward of the dinette. My only concern is what would happen if it encountered an obstruction and got torn off. Would it take part of the belly pan with it?
Cracker
Cracker is offline   Reply With Quote
Old 06-09-2004, 08:34 AM   #11
Cosmotini,
On your 6' carrier, do you have to reach in up to your elbow to get the hose? I know that you can open both ends, but I wanted to keep some of my connection hardware in there as well, and was concernced about not being able to reach them.
thanks,
Tom
Tom
2004 22' Intl CCD
Equalizer
Old 06-09-2004, 10:10 AM   #12
Turtle's Avatar
2004 16' International CCD
Arcata , California
I just used the sheet metal screws to attach mine to the aluminum underbelly. It's held just fine for over 10,000 miles. Nothing, but nothing goes in there except the sewer hose. I highly recommend disposable latex gloves be worn during the whole dumping process.
Turtle is offline   Reply With Quote
Old 06-09-2004, 03:25 PM   #13
cosmotini's Avatar
1963 24' Tradewind
Highland , Illinois
Images: 83
Originally Posted by temcotom
Cosmotini,
thanks,
Tom
That hasn't been a problem because with 2 hoses, they don't really want to go back to their compressed shape and I kind of have to squish them in or they pop out like a jack in the box. I only keep the hoses and the connector in there.
Old 06-09-2004, 11:26 PM   #14
upallnight's Avatar
Wink
Dennis
RAINING? Is this a new Airstream term? Living in central AZ we haven't seen much of the stuff. Actually I think RAIN really exist only in the imagination of AirStreamers who are tired of working on their A/S's.
Leonard
LotalaborAZ
upallnight is offline   Reply With Quote
Sewer Hose Questions (peww) overlander76 Waste Systems, Tanks & Totes 28 06-09-2007 10:01 PM
No Fuss Flush and Fresh Water Hose? docbluedevil Waste Systems, Tanks & Totes 3 04-07-2004 10:07 AM
Short-term storage in central FL? rluhr Our Community 9 12-02-2003 09:36 PM
Long term storage accomodations 85MH325 Our Community 32 11-02-2003 09:52 PM
Spare Tire Carrier Pahaska Our Community 8 08-27-2003 09:00 AM
