Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 02-23-2009, 07:46 PM   #1
MarkR's Avatar
Profile:  1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
Proposed Waste Water Layout
Hi,
I have drawn a diagram of my waste water layout for my 60 Tradewind and was hoping for some feed back. My specific questions/worries:
Can I vent only the tanks and not each fixture (like the diagram shows) (and if I should vent each fixture and don't, what will be the consequence)?
Can the Black and Gray Tank vents join together (like the diagram shows)?
And lastly, are there any issues/problems anyone sees with this layout.
Thanks for your help.
MarkR
Led Balloon in Drag
MarkR is offline   Reply With Quote
Old 02-23-2009, 08:08 PM   #2
Jim Foster
Jim Foster's Avatar
Profile:  1965 17' Caravel
1983 27' Excella
Walnut Grove , California
I might connect the kitchen sink drain to the vent as well to keep water in that trap. I think it might otherwise be drawn into the wash water tank. Our '65 Caravel has such a vent.
What does your physics teacher say? Anyone?
Old 02-23-2009, 08:56 PM   #3
Tom Nugler's Avatar
Profile:  1972 25' Tradewind
McHenry County , Illinois
How many vents do you currently have in the coach? Mine has 3. Two in the rear for the shower and sink and one for the kitchen amidships. I like your plan for the new gray tank.
I would connect the kitchen sink drain to the tank vent and eliminate the extra fitting on the gray tank under the floor.
I would also add a vent to the common bath sink and shower drain with a stack coming up the curbside wall. This would eliminate possible gurgling in the bathroom fixtures when the kitchen sink is emptied. It would also provide a backup if one vent became plugged.
Just remember what free advice is worth,
Tom.
Airstream Forums Member # 2806
WBCCI # 6411
Not All Who Wander Are Lost.
Tom Nugler is offline   Reply With Quote
Old 02-23-2009, 09:19 PM   #4
Jim Foster
Jim Foster's Avatar
1983 27' Excella
I agree. If there is no vent for the bathroom sink, that trap may empty as well.
The traps should keep water in them in order to prevent odor from coming back from the tanks.
Old 02-23-2009, 11:01 PM   #5
r&kweber's Avatar
Profile:  1959 22' Flying Cloud
Seattle , Washington
Mark,
Keep in mind that in a house you can have a drain line up to six feet without a vent. I'd be concerned with your kitchen drain line. I'd look at adding a vent to the kitchen drain line. It should connect with a sanitary T so it will mix air before the six foot mark.
I like Tom's idea of adding a vent to the shower side, except I'd connect the vent to the bathroom sink line, since it is the longest?
What type of tanks are you using? How are you attaching the gray tank to the belly of the trailer? I'm getting ready to do the same. Both my tanks are mounting below the floor.
Nice drawing by the way, mine are totally illegible- like my handwriting.
Ryan and Katie Weber
r&kweber is offline   Reply With Quote
Old 02-24-2009, 09:52 AM   #6
Profile:  1967 24' Tradewind
Redding , California
I'm with Ryan, nice drawing! How did you do it?
SilverHoot is offline   Reply With Quote
Old 02-24-2009, 10:33 AM   #7
Profile:  1963 26' Overlander
Yeah, no kidding, that is a fantastic drawing!
I like the suggestions above, and one other suggestion I would make is that where your black and gray vent lines "y" together on the street side, make that union fairly high up on the wall, so that the gases as well as the drain water don't mix below sink level. It's probably not likely this will happen, but better safe than sorry.
By the way, I think it's fine to tie those two vent lines together, that is the original configuration on my trailer and many others.
Ryan--
My new gray tank is mounted under the floor and has a flange or lip that extends out at the top, and slides comfortably into the c-channel portion of one main frame rail, and the c-channel portion of one x-member. Then I have a removeable support that bolts in from below that supports the lip of the other long side of the tank, with a stop welded on at one end to box the tank in completely. I made it removeable in case I ever need to pull the gray tank to service it, or the floor above it. You can see pictures of this on my blog linked below if you're interested, sometime around mid-December is when I received the trailer back from my frame welder. Just to note, it DOES hang below the belly-pan by several inches. I decided I liked the bigger size I could achieve with this setup.
I'm watching your project with great interest, you guys are blazing fast, keep it up!
Old 02-24-2009, 02:58 PM   #8
MarkR's Avatar
1960 24' Tradewind
Folsom , California
Images: 12
Currently or previously I should say, I only had one vent, it was attached directly to the very small black tank - and after taking off the interior panel I found that it had long since rotted away so the venting was taking place in the walls. There was no gray tank and those lines didn't have any venting.
So it sounds like my theory that having the tanks vented ("unclosed") would be sufficient to prevent the traps from "siphoning thru" is not valid. I just thought that the reason traps would otherwise run dry was because they're normally in a closed system. The real reason (probably obvious) I wanted to only vent the tanks is I'm lazy - I didn't want to take more interior panels off . . . just trying to keep the worms in the can so to speak.
I bought my gray tank from ppl (and it wasn't shown on their website). I'll attach the measurement diagram they gave me. It's going to be installed just like Marcus describes above, and Ryan, I'm going to guess your 59 frame is basically the same. The tank does hang lower than the belly pan but if you keep it close to the axle it shouldn't cause problems AND you can hardly see it (that's my opinion anyway). I'll attach a detail section thru the tank/frame.
I really appreciate the comments/help/advice.
Thanks, MarkR
ID:	75932   Click image for larger version
Led Balloon in Drag
Old 02-24-2009, 07:17 PM   #9
r&kweber's Avatar
I added a single holding tank to my last trailer (a '59 18 footer). It was mounted fully below the frame and was approx. 9" from the ground. I never had any problems with clearance. The black tank I am getting ready to mount (this weekend I hope) will be 5-6" below the frame, so 10-11' ground clearance.
My gray tank will mount in a similar way to Mark's gray tank. The image on the right is really helpful for me to see. My big concern is the C channel is made of steel that was 1/16" 50 years ago and is a bit thinner now. Will that bottom lip of the C hold half of a 30 gallon tank? That's 120 lb. +/- bumping down the road. What are you going to do on the thin side to keep the tank in there? I am struggling with trying desperately to not over engineer the mount. When I'm not sure if it's enough, I like to throw a bunch of heavy steel at it. Then I weld the s**t out of it. I'd like to get to the 'less is more' state before the tanks come in the mail.
Have you thought about dump valves, etc.?
Old 02-24-2009, 07:23 PM   #10
r&kweber's Avatar
Marcus,
I saw the photos of the tank supports on your blog. Nice work! Pictures really are worth a thousand words. I've had something similar in mind, only with more bolts. The black tank on it's way has no mounting flanges, so I'll have to supply something to cradle it from below.
Old 02-24-2009, 08:07 PM   #11
FLYNCLD's Avatar
Profile:  1962 22' Flying Cloud
Bend , Oregon
Great diagrams and advice from all! Here is our gray tank installation, very similar to yours in a 62' Flying Cloud
http://www.airforums.com/forums/blog...tallation-144/
http://www.airforums.com/forums/blog...on-update-166/
FLYNCLD
FLYNCLD is offline   Reply With Quote
Old 02-24-2009, 09:01 PM   #12
toastie's Avatar
1955 22' Safari
Michigan , The Great Lakes State
Mark
You can check my thread Slow floor replacement pages 13-16, installed 2 grays and 1 black.
Will start posting to thread in March, this has been a very bad record breaking Michigan winter.
Toastie
visits our web site www.travelingvintage.com
toastie is offline   Reply With Quote
Old 02-25-2009, 12:57 AM   #13
Profile:  1957 22' Flying Cloud
Odessa , Washington
Hi Mark,
I was just about ready to start a new thread on venting questions when I ran accross yours. Actually I think your original thoughts are correct. Our trailer came w/ no tanks, but everything was vented via a single 1 1/2 inch pipe that terminated under a streamlined roof cap. I think I'm going to stick w/ this method, but add black & gray tnks, of course.
Your Dwg. shows a raised shower pan. I'm just wondering if that will cause any headroom issues. Ours had a mid bath with the shower outbd. There's just no way it would have been comfortable for me. So we're going to great effort to swap positions w/ the toilet. P-trap will probably hang below belly an inch or so w/ a protective cover.
Just some thoughts - good luck w/ your project.
John Whyte
Odessa, WA
(the geographic center of nowhere)
New to this forum, RV'ing & Airstreams
Old Nuke is offline   Reply With Quote
Old 02-25-2009, 10:40 AM   #14
r&kweber's Avatar
Old Nuke -- Good to hear from you! Sounds like everyone here is adding the same stuff.I like the bathroom setup in your trailer, having everything in the middle like that.
Waste Water pipe cap? RetroTrailer 1964 Globetrotter 2 02-21-2008 01:06 AM
my '59 has no waste water tanks. What now? r&kweber Waste Systems, Tanks & Totes 9 08-17-2006 04:45 PM
water and waste systems TStuever Member Introductions 3 06-25-2006 07:33 PM
Waste Water Tanks jalewis Our Community 2 07-31-2003 09:01 PM
Waste Water Outlet Valves Danno Waste Systems, Tanks & Totes 2 06-18-2002 11:48 AM
