Old 02-24-2016, 01:17 PM   #1
rec
1989 29' Excella
anywhere USA , full-timers traveling the country
problem installing the Sewer Solution
I purchased a Valterra Sewer Solution (based on positive reviews from a ton of folks in this community who've used it) -- however, I'm having problems installing it. The way you're supposed to put it on, the water in-flow valve is positioned at 3'oclock and the drain valve is at 6'oclock from the dump exit hole. However, I can't do that because my black tank release handle is in the way -- it's right where the in-flow valve is supposed to go at the 3'oclock position. Has anyone else had this problem? Any idea what I'm supposed to do? Thanks all!
Ramona Creel
rec is offline   Reply With Quote
Old 02-24-2016, 01:26 PM   #2
Echelon73's Avatar
2010 30' Flying Cloud
Mocksville , North Carolina
I got an extension to use on mine with the sewer solution. That brought it out far enough to clear the handles. I got something like this: http://www.walmart.com/ip/29764319?w...474872&veh=sem
Echelon73 is offline   Reply With Quote
Old 02-24-2016, 05:27 PM   #3
rec
1989 29' Excella
Thanks -- we'll give that a try!
Ramona Creel
Old 02-24-2016, 06:39 PM   #4
2007 22' International CCD
Get a clear straight extension. I had the same issue. Apparently got the same one.
KE4GNK/AE
Old 03-03-2016, 05:11 AM   #5
chaseav's Avatar
2015 25' FB International
Yeah, mine too. I basically have to take the hose off when I want to dump the gray water. If I remember correctly...
Absolutely rave reviews about the thing... I'm not one of them. I don't like having to use 7000 gallons of water to dump the tank and wait as long as you have to. Granted, I've never used my full size stinky slinky, just the short one to the portable tank.
chaseav is offline   Reply With Quote
Old 03-03-2016, 08:13 AM   #6
1986 31' Sovereign
Miami , Florida
Well, there are some things the Sewer Solution is not ideal for and one of them is standard issue dumping at a campground dump station. It takes a lot of water and takes a long time, which on a busy morning will not win you any popularity contests. I use your basic stinky slinky for that.
What it is great for is dumping your tanks into a sewer/septic clean out at home, especially if it is some distance from where the rig is parked (or mildly uphill).
The clear extension is handy but you will learn that tomato seeds are indigestible...
Mike
new (usually dirty) Nissan Titan XD (hardly paid for)
Old (enhanced with "male pattern baldness") Sovereign
Young, lovely bride
Goofy dog, dismissive cat
Old 03-10-2016, 07:49 PM   #7
chaseav's Avatar
I agree with the above but I have zero success pumping up hill at all. Not one inch above the valve.
Old 03-10-2016, 07:51 PM   #8
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
weird -- I've been at a few campgrounds with an incline and never had a pump uphill issue.
2011 Airstream International Serenity 28'
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Sewer solution to home sewer-so difficult? lsbrodsky Plumbing - Systems & Fixtures 39 05-05-2018 09:35 PM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
Sewer Solution frozen chosen Waste Systems, Tanks & Totes 20 07-26-2004 07:05 PM
Sewer Solution tomb Waste Systems, Tanks & Totes 4 08-29-2002 05:43 PM
"sewer solution" Chuck Waste Systems, Tanks & Totes 17 08-29-2002 09:17 AM
