Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 08-23-2017, 03:00 PM   #1
Grass Valley , California
Probes for thick-walled holding tanks?
I'm looking for probes that will work on a couple holding tanks that have 3/8" thick walls..
A friend of mine had ProTanks whip up some custom holding tanks for his 73 Tradewind, and the walls of the tanks are too thick to use the Horst probes he ordered..
I tested the Horst probes on a 1/2" thick piece of plastic to see if they would hold, but as I started tightening up the nuts, the probe started backing itself out of the hole, which is what I assumed would happen since the rubber washer on the probe couldn't flare out on the inside of the tank.
Soooo, does anyone have any recommendations for another brand/style of probe I should look into? Possibly some that can be screwed directly into the side of the tank?
Any input would be super helpful. Thanks so much!
mtnroots is offline   Reply With Quote
Old 08-23-2017, 04:34 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
I don't know haw far you are into your install Horst probe install so this may be a moot point, but have you looked at the Seelevel system.
https://www.garnetinstruments.com/pr...onitor-system/
Welcome to the forum
Old 08-23-2017, 05:22 PM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
No need for new probes. 3/8" walls are thicker than they need to be, so it should be possible to countersink the holes for the probes (drill partway through at a larger diameter) to thin out the walls to a thickness that the probes can handle.
Old 08-23-2017, 05:29 PM   #4
2007 22' International CCD
Use s drill press and a forstner bit to get a flat countersink area and depth control...or risk ruining tank!
Replacing water tanks, holding tanks & battery? Nelsons 1956 - 1959 Flying Cloud 57 10-19-2014 08:21 AM
Holding tanks gage is there a key or plugin to test the levels of the tanks. Buckshot 1997 - 1999 Safari 1 08-18-2014 08:25 PM
3 tank probes; 2 lights Chuck Waste Systems, Tanks & Totes 2 08-02-2011 07:22 AM
Need info. on holding tank probes kooshka Waste Systems, Tanks & Totes 4 09-16-2008 07:44 AM
Holding Tank Probes Joe62984 Waste Systems, Tanks & Totes 4 02-05-2004 08:09 AM
