Old 01-27-2016, 12:35 PM   #1
1971 31' Sovereign
Providence forge , Virginia
Possible to eliminate waste tanks?
Ive read through a bunch of threads so far but can't find anything that seems to match what I'm thinking of doing. I've got a 31' rear bath and am doing a complete renovation right now.
I've taken out the black tank and gotten rid of it due to big cracks and corrosion throughout. I thought this wouldnt be a problem as I am going with a composting toilet but my black tanks doubles as my grey also.
I plan to do a fair amount of boondocking but also stay with full hookups also. I've seen where many people use the towable totes to drain their tanks then haul to dump but was wondering if anyone has gotten rid of grey and black tanks altogether and drained grey water in areas that it is acceptable or just drained straight into the tote until time to dump?
Not sure if this is a crazy idea or if it has downsides. Please chime in with some thoughts. Thanks
bswan is offline   Reply With Quote
Old 01-27-2016, 12:48 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
I know you are looking for others in this boat. In the days of old, many campers and trailers used totes because they did not have a grey water tank.
Since you have the plumbing for the grey water, it is likely nearly the same amount of effort to install a new grey water only tank or bypass the tank. I would think a trailer with a grey water tank would be more valuable. Similar to folks who remove the 12V system, there is a certain mind set that will come into play.
sgschwend is offline   Reply With Quote
Old 01-27-2016, 01:21 PM   #3
ArtisanAir's Avatar
1967 28' Ambassador
1964 19' Globetrotter
1960 24' Tradewind
Edgewood , Kentucky
Not having a waste tank might be a reasonable idea for a smaller trailer but why not when you have the ability and the space to put one in?
Its all in how the trailer will be utilized.. you said boondocking? Well a tote will only tote it to.... yea you've got to dump it somewhere before you leave. Where as a tank can hold contents safely and securely until access to a dump station. In other word is if were boondocking it would be a MUST, and while you have the chance you can upgrade to a larger boondocking size tank.
Artisan Airstreams
Custom restorations and renovations
www.artisanairstreams.com
Keeping the Art on the road, one project at a time
ArtisanAir is offline   Reply With Quote
Old 01-27-2016, 03:04 PM   #4
Gainesville , Florida
There are few places in the east where dumping gray on the ground is legal. Keep that in mind.
Old 01-28-2016, 02:21 PM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Without tanks it would be just like a "park model" of old. Those trailers are dependent on full hook-up sites. Many don't go anywhere - they just stay put. Also, back before the '70's it was okay to dump grey on the ground...nowadays, not so much. Very few places allow dumping (even grey) on the ground.
Our '56 started off as a park model trailer - we had NO tanks. You either had to have hook-ups, use a tote for all waste or use a "gopher hole" which hard to believe, but it was acceptable back in the 50's.
We added both black & grey tanks during our restoration and have never regretted it. Our first Airstream didn't have grey tanks and we used a tote, but it sure is nice having them built in.This gives us the freedom to stop anywhere and use our trailer however we want with or without hook-ups - more flexibility. If you had to drag out a tote every time you wanted to make a "potty-stop" that would be a PITA and then you have to figure out where to dump...or carry around your semi-full tote until you find a place to dump. Even grey water stinks after awhile.
The problem with blue-totes is the "up close & personal" element on dealing with your waste. The tanks tend to be on the smaller side so they are manageable to lift & carry which means that you will be toting your waste quite frequently.
A composting toilet would help...but I can't think of a good reason to forego built-in grey tanks - in doing a restoration. As mentioned earlier, it helps with flexibility & resale as many will not have the same mindset.
Grey tanks are not much more (if at all) expensive than blue-totes and are not that difficult to install and they add a huge "out-of-sight, out-of-mind" aspect to taking your trailer out. You just pull the valve when dumping - no heave-ho off to the dump we go.
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 01-28-2016, 02:31 PM   #6
Kevin245's Avatar
Shari
X2. Sage advice from an experienced restorer.
Eleanor Roosevelt
Old 01-28-2016, 03:29 PM   #7
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Agree
Shari
My 55 was also a park model when I got it. I added fresh, black and gray water tanks and never regretted it. If you travel with your trailer you will want tanks.
BambiTex is offline   Reply With Quote
Old 02-14-2016, 01:02 PM   #8
2012 27' Flying Cloud
Denver , Colorado
I agree with the others, keep the gray tank. We boondock on our 5 acres in the Colorado mountains a lot so we installed an AirHead composting toilet two years ago. It works great, no smell, very little fuss if you keep it clean. I installed it in place of the water toilet, so it sits on top of the black tank. We cut into the black tank vent pipe for the AirHead that needs a constant muffin fan running. Our solar panel keeps the batteries charged and the fan running all year. The AirHead is a couple of inches too high for comfortable use because it sits on top of the "remains" of the black tank (had to cut the neck off that supported the water toilet). Now I'm considering removing the black tank altogether and keeping the gray. Not sure how best to do that, but I'm researching.
Good luck.
Jim and Marsha
JimmyT is offline   Reply With Quote
Old 02-14-2016, 01:26 PM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I resemble that remark. "In the days of old" grey water was drained right on the ground and the blue boys were for the black tank. Owners manuals of that era also describe digging a hole and running your sewer hose in the hole and then filling it in. You can hook the larger totes to your trailer hitch and tow the tote to the dump station. Personally speaking this can lead to some embarrassment when the cover pops off while towing to the dump station leaving a brown, wet trail. I still have and use my blue boy on my 71.
Eliminate WD issue with water! gamana Hitches, Couplers & Balls 68 10-28-2015 07:03 PM
Eliminate Roof Vents?? Zenstream1 Roof 10 08-02-2015 09:34 PM
How do I eliminate the musty mouse smell?? mrrealtor General Interior Topics 30 04-16-2015 05:00 PM
First dog in AS - how do you eliminate that dog smell? Whirlaway The Pet Forum 42 03-22-2010 06:54 PM
Eliminate black water tank? macman Waste Systems, Tanks & Totes 17 07-02-2006 10:47 AM
