Old 06-11-2008, 10:16 PM   #1
chaimemet's Avatar
2008 31' Classic
Ft. Lauderdale , Florida
Portable Tote
Looking at non full service state parks and will need a Tote due to over active life-style. Which brand? Are low profile models necessary? Where do we store these convienences?
chaimemet is offline   Reply With Quote
Old 06-11-2008, 11:21 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Can't help with the brand...
Low profile makes it easier to get the water from the dump valve to the tote.
I stored mine in the tow vehicle when I used one.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 06-11-2008, 11:33 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Other things to consider:
Ease of pulling: larger wheels are better...also a handle that allows you to put it on a ball hitch and tow it to the dump site...
Size: bigger isn't necessarily better...don't get one so large that you can't lift the thing into your truck when it's full if you need to...
Features: some have all the "pieces" you need built in...hoses, connectors, auto shut-off, handle that fits on a ball hitch, etc...that's what I would want...
I can't really say what brand is the "best" but you should be able to find several options if you look around on line...here's a place to start...a Thetford model sold at Campingworld:
Thetford SmartTote and SmartTote LX Portable Waste Tanks - Camping World
Good luck! Let us know what you decide to get and why...
TB & Greg and Abbey Schnauzer
#3954
Old 06-12-2008, 07:06 AM   #4
1999 25' Safari
Port Huron , Michigan
Trailer height???
Hi I have a 99 safari which I found was too low to the ground for gravity to work when emptying your black or gray water tanks.I would make sure your trailer is high enough fot the tanks to empty into the tote, REMEMBER s--- or sewage doesn't run up the hill .Seriously My trailer is only about 8 1/2 inches inches tall where the black and grey water emptyping gates or tubes are. I know the height differs with other A/S years and models. I bought a tote one of the "blue boys" and its just too tall.I often wonder if other A/S trailers have this problem.Just measure 1st too be sure.Good Luck!
Michigan Silver
mi silver is offline   Reply With Quote
Old 06-12-2008, 10:27 AM   #5
chaimemet's Avatar
2008 31' Classic
outlet height
called AS CS the nearest model they had to mine has an external outlet pipe height of 9" +. The Thetford 18gl XL model has a height of 14"3/8.
Old 06-12-2008, 10:55 AM   #6
dnrtheil's Avatar
1964 24' Tradewind
Portage , Michigan
We use a blue tote, it'll just fit under the back of the Tradewind depending on how level the ground is. If it will not fit under the back I have a 10' garden hose section, so I can move the tote farther away and still place it under the Airstream, typically I'll use a hose about 12" long. I had a Thetford Smart tote first, but the 3" sewer hose that is permanently attached, is attached at the bottom, so I sent it back. So far in the one year I've owned our A/S I have not had to dump the black water into the blue tote, just use it for grey water. I thought that if I ever had to dump the black tank into the tote, I would not want the sewer hose to connect at the bottom which is why I sent the Thetford back and found this blue tote on Craigs list for $50.00 plus shipping. I am pretty sure its a 25 gallon model and does not have a bar to hook to the truck, juts a molded handle. I currently use a length of chain with a vinyl cover and two hooks, in which I can hook it to the tow vehicle and pull it to the dump station, or to the bumper of the A/S if we are leaving for home.
Derek
Operation "SAVE RUDY" Strike Team (Associate Member)
dnrtheil is offline   Reply With Quote
Old 06-12-2008, 01:13 PM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I got a blue 22 gal Tote Along blue boy rather than a Thetford. The product reviews on the Thetfords were not that great. Personally speaking much less than 22gal is not enough volume. Much more and you need a forklift. I second the above post that being able to tow with a hitch to the dump station is very very handy.
Old 06-12-2008, 01:45 PM   #8
chaimemet's Avatar
2008 31' Classic
Tote height
I see in the manual pictures that the LX model has a flexible neck that can lower the hose height.
SmartTote Portable Tanks
"Pull out the sewer hose (Fig. A). If 1. necessary, lift the finger tab to lower the hose.
Remove the sewer hose cap.2.
Connect the sewer hose to the RV dump"
So it seems then that by hooking up this way you can get around the problem of the height of the tote being at 14 5/8" and the AS at 9" +. Pressure from the AS tanks will push the grey/black out anyway.
Old 06-12-2008, 02:17 PM   #9
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
I can vouch for the Thetford not being a "quality" product. I bought one early on when there were few reviews. Got mine at Camping World. The bottom connecting hose constantly comes off so I always have to check it - YUCK. It does not empty fully - even with the lifting and sloshing to try and rid it of all the fluid - there always seems to be a cup or two remaining. Makes it difficult to clean out when placing back in storage. I have used mine for both black and grey - so cleaning was a necessity.
Maybe I'm not a tote person - just the thought of using one makes me feel yuckey.... Gotta go take a shower now....
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 06-12-2008, 04:42 PM   #10
easyride's Avatar
1977 27' Overlander
1963 19' Globetrotter
Naples , Florida
Just bought a Tote-along on Ebay,22 gal with all accessories[I did have to add Thetford end on short hose they sent] I think it was $107.00 + aroud $ 20.00 ship. I couldn`t find anything near that anywhere else. Dave
easyride is offline   Reply With Quote
Old 06-12-2008, 06:15 PM   #11
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
Your thread was a reminder that I needed to order a tank for the Argosy.
Haven't ordered anything from JC Whitney since driving a VW in the 60s.
Here was the info.
22-gal. 2-wheel Tote-along Portable Drain Water/Holding Tank
Item ZX186199U Original $162.39 Sale $99.99
Includes all the connections and the vehicle towing bracket.
Today's (maybe everyday) special was no shipping cost for orders over $75.
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 06-12-2008, 06:26 PM   #12
easyride's Avatar
1977 27' Overlander
Naples , Florida
Angry Ripped Off Again
Here was the info. on a 22 gal.
22-gal. 2-wheel Tote-along Portable Drain Water/Holding TankZX186199UEach$162.39
$99.99
You had to post that just to make me feel bad dave
Old 06-12-2008, 06:40 PM   #13
empresley's Avatar
1977 Argosy 24
Central , Georgia
Sorry... not intended.
Come to next year's CanOpener & a few adult beverages will be our treat.
Old 06-12-2008, 06:52 PM   #14
easyride's Avatar
1977 27' Overlander
Naples , Florida
May have to do that,just getting time off is hard part. Dave
Best size blue boy tote? Lumatic Waste Systems, Tanks & Totes 23 06-14-2010 05:29 PM
Which Tote Tank ? JuliaPowell Waste Systems, Tanks & Totes 6 03-03-2008 08:59 AM
Tote Along Devoman Waste Systems, Tanks & Totes 16 11-27-2005 06:29 AM
tote tank ideas bimi Waste Systems, Tanks & Totes 10 04-12-2005 01:09 PM
Tote Tanks Dwight Waste Systems, Tanks & Totes 4 10-09-2002 06:13 AM
