Old 02-07-2014, 04:19 AM   #1
1972 27' Overlander
Denver , North Carolina
Porta Pottie
Hey Folks,
I am deep into the bowels of my rear end separation repair. I've started pondering the advantages of doing away with the black tank entirely and going with either a composting toilet or a very high end porta Pottie Thetfords curve comes to mind. We use a porta on our boat which requires dumping every summer. We use it for all facets of the job..,
My thoughts are two fold. 1 no tank, no stinky slinky I can dump the cassette virtually anywhere there is a toilet. 2 with either a porta or a composter I still have the dumping so why not save quite a bit of cash and go with a porta .
As always your thoughts would be appreciated.
Lucky Dave
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Old 02-07-2014, 04:56 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Won't you still need a slinky for your gray tank?
Or is your Airstream old enough to not have separate gray and black tanks? In which case, if you get rid of the black tank, where does your shower and sink water go when you replace your only tank with a cassette toilet?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-07-2014, 05:42 AM   #3
Gainesville , Florida
72s did not have gray tanks. We have a Porto potty in our Avion and it has never been a problem as long as you have access to a dump station or restrooms. Gray water has to be dumped properly anyway. When we get rid of the gray water, we dump the Porto at the same time. If we have sewer at the site, we dump the Porto down the on site hole, the gray water goes there anywhere. Our Porto holds 5 gallons. Jim
Old 02-07-2014, 05:57 AM   #4
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I applaud those who can live with a Porta. many years ago I had a boat with one and I got tired of having to cart the thing to a toilet. We also got tired of the perfumed smell in the boat from the chemical used to disinfect and mask the fecal odor. I did some extensive work to install a bladder holding tank, pumpout, and real marine toilet. I would never go back to a Porta.
Larry
lsbrodsky is offline   Reply With Quote
Old 02-07-2014, 06:15 AM   #5
2013 20' Flying Cloud
Cream Ridge , New Jersey
We have camped with both over the years. You don't mind hauling a porta to the dump station when you're younger but it gets to be a real drag as time goes on. The cassette is easier but you're still carrying five or so gallons to wherever you're going to dump. Maybe a small two wheeled cart of some type. My personal choice at age 69 is the permanent install but as with most amenities it depends on how much aggravation you are willing to put up with. Different strokes for different folks.
Joe Palmieri is offline   Reply With Quote
Old 02-07-2014, 07:27 AM   #6
sigv's Avatar
1963 24' Tradewind
Pittsford , New York
Go Porta
I would go with the porta potty the ability to dump at any restroom and not have to wait in line or get out the rubber gloves is a huge plus. If I were to do it again that is what I would do for sure.
Hey Folks,
Lucky Dave
sigv is offline   Reply With Quote
Old 02-07-2014, 08:01 AM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
We used a portapotti in our 54 and it worked out well. With a permanent tank we apply the same principal by dumping into a 5 gallon blue tank every two days that can be carried to a restroom or porta john when camped where there is no dump station.
If the tank weight is a problem just empty it more often.
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 02-07-2014, 08:42 AM   #8
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Our our 54 FC we're going with a Natures Head composter. Benefits over porta-potti are they separate the liquid from the solids. The liquids can be then taken separately to be desposed of, and the solids are composted down in the toilet for easy disposal.
I plan on having the liquids drain into our 'grey tank' which is vented, so will only have to dump the solids once every couple months or so.
Barry & Karen in Mi.
goshawks00 is offline   Reply With Quote
Old 02-07-2014, 08:50 AM   #9
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
We ditched our black tank use a Porta potti. Works great. We use a blue boy for our grey water and it works good for us as well. Most sites don't have full sewage hook ups so its either hook up the trailer, go dump , then return to the site. Whata pain! Not to mention no Black tank means less junk in the trunk ,less weight, less chance of floor rot around the toilet flange.
We use the Thetford 550e. Nice unit! We can get three days until dumping it. Two if its a beer night.
Sent from my LG-E617G using Airstream Forums mobile app
Cyquest is offline   Reply With Quote
Old 02-07-2014, 10:30 AM   #10
Wise Elder
Jammer's Avatar
2010 30' Classic
He
As with so many things RV-related, much depends on your use case.
We travel as a family of 5 and often stay in state parks where the public toilet facilities are substandard (distance/cleanliness). Hence the toilet in the trailer serves all needs. A porta-potty would fill up quickly. We have to stop at dump stations to dump greywater, anyway, so having to dump a porta-potty as well would just be an extra step. The few times I've used them I've found them to be difficult to keep clean and sealed.
I know that the b-van crowd swears by porta-potties. For some camping styles I can see how they would work well.
Old 02-07-2014, 10:33 AM   #11
But I'm ever so glad that my Airstream Interstate B-van has a wet bath and black tank instead. Especially since it has also got a macerator pump so I don't have to mess about with a slinky.
WBCCI #1105
TAC LA-4
Old 02-07-2014, 11:00 AM   #12
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
I installed a Thetford Curve in our 66 Tradewind and it works well for us. The black tank now acts as the gray tank for sink and shower water. See Dan's 66 Tradewind Improvements (post 23-30) for details.
We only pea in it. We can go 5 days normally. It is cheap, lightweight, easy and clean. Whats not to like?
Dan
Old 02-07-2014, 04:47 PM   #13
1972 27' Overlander
Thanks all for your repkies! Here is what I will do: Fix and reainstall the Galvanized pan for the black tank. Install the plumbing, basically have it ready to go should I ever decide I need a black tank. I looked hard at composters and they are very nice but out of budget. The Thetford Curve on the other fits nicely into my budget and I can spend the money elsewhere. Thank you all!
Lucky Dave
Old 02-07-2014, 08:44 PM   #14
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Fyi.There's a hold down plate for the Thetford Curve so it stays in place during transit.
What Did You Get For Your Trailer Today? PeterH-Airstreamer Our Community 5401 05-17-2018 08:45 AM
Dan's '66 Tradewind Improvements TouringDan 1959-69 Tradewind 197 05-11-2018 06:27 PM
