06-05-2009, 03:40 PM
1967 24' Tradewind
Greenville
, South Carolina
Polyethylene or ABS for waste tanks?
I've searched and cannot find a consensus as to what to use. So far the differences that I've gleaned are with ABS it is easier to add your own outlets and inlets just utilizing the fittings and some ABS cement. The poly tanks can have them added also but is done with rubber grommets and fittings and seem as if they could be a source of failure. Just learning here so would love to hear some more opinion.
Thanks, Mike
06-05-2009, 05:19 PM
1977 27' Overlander
1963 19' Globetrotter
Naples
I bought the ABS because a person on Ebay has 36 gal for $50.ea,and since I`m redoing the whole frame cross members,it worked for me.Dave
06-05-2009, 07:47 PM
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
I like the ABS tanks because you can glue your fittings. Hang the tank,drill the hole, you cant miss! "RV Surplus" has a great slection.
Bibbs
07-21-2009, 04:27 PM
1973 31' Sovereign
Portland
Dave,
The tanks you are referencing on EBay might work for me as well. Have you received them yet? If so how do you feel about the quality?
Malcolm
Only he who attempts the ridiculous can achieve the impossble.
07-21-2009, 04:34 PM
Corona
tank material
Fiberglass tanks, we think are the best.
Nothing to heat, nothing to mold and nothing to crack, in time.
Fittings can easily be added most any where on those tanks.
Should one get damaged from an accident, they can easily be repaired, by most anyone.
07-21-2009, 05:18 PM
1968 28' Ambassador
Cedaredge
Most rv dealers can spin fittings onto the poly tanks and it's not to expensive $10 each at my rv dealer...
Jason
May you have at least one sunny day, and a soft chair to sit in..
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
