Old 06-17-2007, 01:34 PM   #1
kalispell , Montana
plywood in holding tank
We just got back from the first trip in our airstream. We bought it used, but it had never been used at all. We camped for two days and it was awsome. The old suburban pulled it fine althouogh I could tell more power would be neccesary on a longer trip for sure. A moment ago I was emptying the holding tanks, I use a macerator pump that grinds and pumps the contents thru a regular garden hose. I have used them on our bus for many years. About a minute into the dumping The pump sounded strained then popped the 15 amp fuse that is on the on off switch. This had never happened before. I replaced the fuse with another and it popped, I replaced it with a 20 amp and it managed to churn the remaining few gallons thru but sounded labored. When I removed the pump from the airstream a piece of plywood about two inches long and a half inch wide with a circular shape on one side fell out. Not so nice. I should have removed it as soon as I heard it grinding. So a better idea would be to not use a macerator pump on the very first dump as there may be construction debris in the tank that is too hard for the pump to chop up.
Robert Rahn
Kalispell, Mt.
2006 25 safari
chaunceyboy is offline   Reply With Quote
Old 06-17-2007, 01:40 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
My dad's company found an entire vacuum cleaner inside a commercial jet fuel tank. It had been there for several trips.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-17-2007, 01:49 PM   #3
kalispell , Montana
vaccume
i will look int there with a flashlight i think. wow a vaccume cleaner, i wonder if it still worked. if i was vaccuming out a fuel taank in an big plane I could imagine being in a hurry to get out. recently I installed some vents in a dirty attick and left several tools up there and had to go back to get them.
Old 06-17-2007, 01:53 PM   #4
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Uh... Well...
How can you defend that one. It sounds like a someone had a bad day at work. It looks like a scrap from the cutout for the closet flange fell into the tank.
Second issue sewage grinders, I have a problem with them because of just this type of incident. What do you do when the pump grinds to a halt because of a foreign object in the tank (Grand kids toys...), you are in very big trouble.
I'm glad it worked out for you and you are correct in that you should purge all tanks the first time out. This would include sterilizing the fresh tank.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 06-17-2007, 03:41 PM   #5
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Interesting. Probobly the first of many things you'll find throughout your ownership.
Can I use "regular" antifreeze in my holding tank? Luckydog Airstream Motorhome Forums 6 11-25-2002 07:01 AM
Holding tank valve pull's camphost Waste Systems, Tanks & Totes 3 10-31-2002 11:11 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
tradewind holding tank McGill Waste Systems, Tanks & Totes 3 06-22-2002 09:28 AM
Holding Tank Wiring 74Tradewind Waste Systems, Tanks & Totes 1 05-23-2002 04:22 PM
