Wow I don't have a screen because last week I found an old bee nest out of it and snaked it out from the top.
Should I get the factory gaskets or just get something from NAPA and make my own?
One last point doesn't the cap need a weep hole for the water that gets in the cap?
If you saw the damage this did to the floor........I cut a 30x48 hole near the bath just off center to fix the wood rot.
Then I saw the real mess glubbed up pink wet like a sponge insulation, as I said in some of my other posts this insulation is the achiles heel of the AS.
I took it all out of the front and rear belly pans including the bannana skins.
It was all useless and heavy.
After I clean all the steel up and POR it it will get closed up with NO insulation.
I'm fiberglassing the floor inside, then putting on a layer of R-14 bubble, then pergo.
Now there was a silver lining in all this.
one of the waste gates was dripping, now I can fix them from above thru the open floor.
Are rebuild kits avail for the Thetford 1447 valves?
