Old 11-08-2014, 11:24 AM   #1
drftboat's Avatar
2012 16' Sport
2015 19' Flying Cloud
Seattle , Washington
Plumbing Experts-Toilet flush pedal leak - Dometic
Calling all AS plumbing experts. OK here is the deal..... I hooked up to shore water and developed a strong leak from the flush valve mechanism on my Dometic toilet in my new to me 2012 16 ft Sport. Did I blow up the inner seals due to high pressures? I took off the round aesthetic cover plate and witnessed the leak dripping/flowing from the +/- 1/2in black cap on the bottom of the valve assembly. I also noticed two black plastic adjustment screws? My owners manual package did not contain Dometic toilet manual. Ideas?????
drftboat is offline   Reply With Quote
Old 11-08-2014, 11:48 AM   #2
drftboat's Avatar
2012 16' Sport
Please see picture of leaky flush valve discussed above. Click image for larger version
Name:	ImageUploadedByAirstream Forums1415472440.477279.jpg
ID:	225997Click image for larger version
Name:	ImageUploadedByAirstream Forums1415472470.012383.jpg
Old 11-08-2014, 11:59 AM   #3
Castaway's Avatar
2012 25' FB Flying Cloud
Celina , Ohio
I had to replace ours already, easy to do. Dometic is pretty popular so you should be able to find one at any RV store or Camping World has them
Gary
Castaway is offline   Reply With Quote
Old 11-09-2014, 11:28 PM   #4
drftboat's Avatar
2012 16' Sport
Gary
Thank you.
Doug
Old 11-10-2014, 11:25 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Easy to replace and can be bought online for $30.
I neglected to winterize mine properly and it froze. I'll do better this year.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-10-2014, 12:02 PM   #6
Will_Brule's Avatar
2014 25' FB Flying Cloud
Palestine , Texas
Yes. Freezing is the most common cause. You may need to check your shower head and if you have one, the outdoor shower head. Both are common casualties after a freeze.
Will ~ "Blue Skies"
WBCCI #31443
"Don't follow me.
I've spent my life leading folks astray."
Will_Brule is offline   Reply With Quote
Old 11-10-2014, 12:53 PM   #7
m.hony's Avatar
2013 30' Classic
After a busted toilet valve I will always use compressed air to blow water out of the lines and then put pink antifreeze in it.
I will never forget the toilet valve or black tank flush again.
TAC #MS-10
Airforums #70955
Old 11-10-2014, 06:49 PM   #8
dznf0g's Avatar
Oswego , Illinois
or the toilet spray head, if you have one....easy to forget!
-Rich-
Old 11-11-2014, 01:00 PM   #9
m.hony's Avatar
2013 30' Classic
I did the whole winterizing thing yesterday. Got the toilet and black tank flush. Everything has pink in it except the black tank flush. Should I put antifreeze in it? Or is blowing it out with air sufficient?
TAC #MS-10
Airforums #70955
Old 11-11-2014, 02:08 PM   #10
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I blow the black tank flush with air only. I'm not sure of how it's plumbed so don't know if there is any place for water to sit. Blowing it out has worked for our NJ winters.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-11-2014, 04:29 PM   #11
m.hony's Avatar
2013 30' Classic
It basically goes straight to the poo jets/dung blasters with a back flow valve inline. Last winter I left water in it and it busted. If blowing it out with air is good enough in New Jersey, then it's good enough in Mississippi. Thanks for the extra little bit of peace of mind. I'm confident that everything will be OK.
TAC #MS-10
Airforums #70955
Old 11-11-2014, 05:36 PM   #12
retired USA/USAF
2001 30' Excella
Did you repair it yourself ???? How is the access to reach it ???
Just thinking ahead, in case
Roger in NJ
TAC - NJ 18
Old 11-11-2014, 08:04 PM   #13
m.hony's Avatar
2013 30' Classic
The repair was done at Jackson Center, but would be an easy DIY repair. The valve is on the wall under the bathroom sink in my trailer. I did replace the toilet valve myself- ordered it off Amazon.
TAC #MS-10
Airforums #70955
Toilet pedal leak - '06, Bambi rportillo Sinks, Showers & Toilets 9 04-09-2014 10:50 AM
Slow leak on toilet flush pedal lewishw Sinks, Showers & Toilets 3 11-04-2013 05:57 AM
64 overlander toilet flush pedal surfscoter Sinks, Showers & Toilets 7 03-07-2011 12:30 PM
'75 Argosy trailer toilet 'flush water leak' Derek Gardner Sinks, Showers & Toilets 2 10-26-2010 07:04 PM
Broken foot pedal on toilet Share All Sinks, Showers & Toilets 1 07-04-2009 08:08 PM
