Old 07-28-2009, 11:26 AM   #1
Silverslug75's Avatar
1973 31' Sovereign
Vashon , Washington
Permanently hooking up to septic system?
I am going to be remodeling my friend's 31' Sovereign's rear bathroom. I am not familiar with remodeling Airstreams, I am just an amatuer handyman helping a friend. This AS is no longer going to be a road traveler ever again...strictly a stay-at-home cabin in the woods. Jo Anne wants a conventional household flush toilet, and this is getting hooked up to a sceptic system. Will I need to take out the old toilet's waste holding tank? I imagine if I just leave the tank there with the gates open there will be "poop pile-up" in the holding tank. Anybody have a few helpful opinions? I don't know anything about how RV toilet systems operate or how they are normally hooked up to sceptic facilities.
Silverslug75 is offline   Reply With Quote
Old 07-28-2009, 11:42 AM   #2
Iwannagocamping
Dakota's Dad's Avatar
Rineyville , Kentucky
Well... The toilet dumps straight down into the holding tank. To do what you plan, I do believe the black tank will need to be removed, then just plumb as you would normaly I guess.
See our blog here on how two RV/AS rookies tackle a 1979 Sovereign resto!!
Just the photos.. (sometimes you don't need the blog, just a picture worth a thousand words..)
1979 Sovereign International
2004 Ford Expedition Eddie Bauer
2 Golden Retrievers
Air #36788
TAC#3179
WBCCI #1265
Dakota's Dad is offline   Reply With Quote
Old 07-28-2009, 01:57 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
The problem you mention is a common one with a lot of SOB trailer that have the bathroom on the curb side of the trailer, never enough water to move the masses. If your Airstream has the toilet on the street side, close to the dump valve and you are using a full tank of water per flush you should not have a problem. Depends on how much time and effert you want to put in.
2004 Excursion 4x4
Old 07-28-2009, 02:59 PM   #4
2008 16' Safari
Destrehan , Louisiana
The best thing to do is to remove the old black water tank and plumb it straight out. The tank will act as a trap and you'll end up with a small brown mountain in there.
dlb435 is offline   Reply With Quote
Old 07-28-2009, 03:27 PM   #5
HowieE's Avatar
Images: 12
Now that I think about it you may have to remove the tank, not because of your stated concern, but because a standard toilet will have it's termination about 8 inches further back than a trailer toilet. This may change the location of the toilet and require a new location for the closet flange.
2004 Excursion 4x4
sceptic, tank, waste, holding tanks
Building a septic system GolfStream Waste Systems, Tanks & Totes 21 03-26-2007 07:39 AM
Plumb black water tank to septic system? '72Tradewind Waste Systems, Tanks & Totes 5 09-10-2006 09:32 PM
Septic system hookup rfield54 Waste Systems, Tanks & Totes 3 09-04-2006 07:48 PM
Black water tank with septic system rfield54 Waste Systems, Tanks & Totes 3 09-26-2003 06:31 PM
I want to connect permanently to local sewer Jaime Esparza Waste Systems, Tanks & Totes 1 09-09-2002 08:49 AM
