08-06-2004, 03:41 PM
Oregon City
, Oregon
Oversized Thetford dump valve connector
My 66 Trade Wind has a white thetford female connector with the ears on the dump valve that accepts the hooks on the hose connector. The one that fits is oversized from the standard thetfords! It is oversized by the width of the hooks on each size!
Is this common and where do I get the oversized fitting? Am I destined to replace the connector? Glenn
08-06-2004, 07:47 PM
a.k.a. Ambassador Tim
1960 28' Ambassador
Northern
I'm not sure what you mean by oversized but I remember having trouble with this when I purcahsed my trailer.
It seems the current standard for sewer hoses is the valterra connection. Where AS uses the Thetford. Which is your white connection.
So you will need a Thetford to Valtera adapter availble at most RV suppy stores. This way you can buy hoses and connections with the valtera fittings and everything will work fine.
I hope this is what you needed. If not, someone will be along soon to correct me!
Good luck.
08-07-2004, 08:31 AM
Putnam
, Connecticut
Tim is correct as I have the same issue. Saw a new Bambi at Region One Rally yesterday. It has Velterra dump fittings. The Safari that was there has Thetford. As if things weren't hard enough.
Try this place for Thetford fittings.
http://www.dyersonline.com/merchant.mvc?Screen=SFNT
08-07-2004, 10:50 AM
Contributing Member
Austin (Hays County)
The Thetford costs more, but the quality and operability of their product is head and shoulders above the Valterra stuff. I was at first dismayed when I had to buy a new, expensive hose fitting for my Classic. After using the Thetford fitting for a while, I am quite glad that Airstream used that product. The dump fitting goes on and off effortlessly where the Valterra fitting on my previous Airstream would jam and taxed the streangth of my arthritic hands.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
08-07-2004, 11:01 AM
1960 28' Ambassador
Northern
John,
Where do you get a sewer hose with a Thetford fitting? Everywhere I look, which is basically camping world only stocks Valterra.
That's why I went with the Thetford to Valterra adapter.
08-08-2004, 05:28 PM
1966 22' Safari
1979 30' Argosy
Armada
, Michigan
Tim,
I too have been playing the sewer house adapter game, and I have a real tight fit on the '66. I just went to the Dyer's RV link that Over59 posted, and they have the fittings that fit the Thetford. You supply the generic RV sewer hose. Gonna order one here in a minute.
JOhn
08-12-2004, 07:28 PM
1960 28' Ambassador
Northern
Thanks for the info John and Over59.
I'll check it out.
08-16-2004, 05:09 PM
2005 28' International CCD
Pagosa Springs
Which hose connector
Anyone know if I need a Valterra or a Thetford coupler for a 2005 CCD 28'. Can't find the answer in the pdf. Thanks.
"would you rather have a mansion full of money or a trailer full of love?"
08-16-2004, 05:24 PM
Just a member
1978 28' Argosy 28
Lutz
The only Airstream trailers that use the Valterra are the Safari models.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
