07-13-2011, 01:51 PM
1978 31' Sovereign
Oakley
Opinions welcomed.. Valterra or Thetford
I am at the point in my rebuild where I am preparing for replumbing of all tanks and fixtures. So, what would you'all go with...valterra or thetford waste valves? If I go valterra, should I stick with the current black pipe sizes or go down a notch? This is on my 1976 Argosy 26
07-13-2011, 02:01 PM
Wise Elder
2010 30' Classic
South of the river
Parts and accessories are readily available anywhere for Valterra valves, which are now the industry standard. Thetford components are more expensive, harder to find, and available in fewer configurations.
I believe Airstream stayed with Thetford as long as they did primarily because of the cost and hassle of re-engineering existing assemblies and switching over production.
08-14-2011, 07:58 AM
Tool Hoarder
West
I think Im going with Valterra looks like great stuff
08-14-2011, 08:11 AM
1967 24' Tradewind
Greenville
, South Carolina
I went with Valterra for the exact reasons that Jammer stated.
08-14-2011, 10:24 AM
1960 26' Overlander
1963 24' Tradewind
El Paso
I did Valterra on mine, more readily available parts.
08-14-2011, 10:45 AM
Always learning
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central
Valterra. Decent quality, not expensive and available nearly everywhere including Walmart.
Lance
08-14-2011, 12:38 PM
2007 23' International CCD
Lapeer
, Michigan
Had the factory service department change the Airstream's OEM Thetford termination part to Valterra to allow for the most options and avoid having to use a Thetford to Valterra adapter. As mentioned before many systems and suppliers have Valtera parts. Well worth the convenience to have universal replacements available without monkeying around with this to that fitting.
08-20-2011, 09:06 AM
1997 28' Excella
Eden
, Utah
I just had both valves replaced with Thetford valves. The PO had not winterized the unit properly and the sleeves that fit to the tanks were cracked and leaking. The RV service center I had do the work wanted to replumb and put in Valtera, but I resisted and told them I wanted OEM. This put my vacation off by a week and caused a lot of frustration with my family. After much searching I finally found the Thetford sleeves from inland, (called thetford they told me they are no longer available). If I had it to do over I would go with Valtera.
HankO
08-20-2011, 10:27 AM
Don McKelvay
1994 34' Limited
London
, Ontario
All good posts about the Valterra as they are cheaper and available almost everywhere. However, my experience has been the ears break often whereas even 35 year old Thetford ears are still in great shape. While working with the Intl Sanitation crew we continually broke new Valterra ears. If Thetfords were more available I would stay with them, but sadly things have changed and only a few places stock them anymore.
________________
Don McKelvay
WBCCI #205
AIR #42
1994 34' Limited
2004 GMC 2500 HD
Hensley Hitch
08-20-2011, 10:31 AM
Corona
Many Airstream dealers in the US, stock Thetford parts.
08-20-2011, 04:12 PM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
I have had the opportunity to compare side-by-side . . . . Thetford on my Airstream and Valterra on my Argosy . . . . to me there is no question . . . the QUALITY choice is Thetford. I have never had a part break on my Overlander's Thetford setup . . . but I am on my third round of replacements on the Valterra parts on my Minuet. The next time the Valterra breaks on the Minuet . . . Thetford goes back in . . . .
Good luck with your investigation!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
08-20-2011, 06:11 PM
1967 26' Overlander
Winston Salem
, North Carolina
I think AS today uses Valtettra products.
Easier to find parts for.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
08-20-2011, 06:12 PM
1967 26' Overlander
Winston Salem
, North Carolina
my 501st post...
Greg
Winston Salem, NC
WBCCI 5218,
08-20-2011, 07:40 PM
1978 31' Sovereign
Oakley
Originally Posted by Silverwanabe
my 501st post...
Congratulations!
