Old 06-28-2013, 05:56 PM   #1
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
Onerous Task Less Onerous
For those of you who've followed my posting on the Drainmaster system, here are a couple of shots of the installed product on SilverLeaf. Notice the really classy drain unit...which has a clear section AND a valve at the termination point. You'll also note that I have added two Barker electric valves to open and close the black and gray tanks from INSIDE the trailer. Photo is of the Black toggle switch (there's also one for the Gray -- suitably marked). You push the switch --which I installed in a convenient cabinet to open the valve. When the valve is fully open a red light flashes .... a good reminder that if that red light is a flashin' you better close it before you're sorry! None of us particularly enjoy this very necessary part of Airstreaming. (Oh, I also will have the manual valve handles close at hand in case I ever have electrical failure and need to dump.)
ID:	189563   Click image for larger version
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-28-2013, 11:02 PM   #2
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Kewl. Total cost on that?
Peace and Blessings..
Channing
WBCCI# 30676
Old 06-29-2013, 06:00 AM   #3
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Very creative! Does the hose stay attached to the tank and ride in storage somewhere or do you still have to don the gloves and attach for each dumping?
Old 06-29-2013, 03:13 PM   #4
BAB
BAB's Avatar
2015 30' Classic
Check the drainmaster website for pricing data (I added an extra length of hose and an adapter that would let me use their cam system but adapt to the Valterra if I had to). And, yes, the hose fits in the bumper compartment. The Barker valves are available online or at CW. One is for the 1 1/2 inch (gray), the other is a 3" (black)....around $130 each. Also had to buy wiring to install switches inside the trailer...so to make the onerous task less onerous I probably $700. Not counting my labor which is VERY high.
_________________
ProPride 3P
AIR# 58452
