Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 10-21-2002, 12:43 AM
Anna
Anna's Avatar
Profile:
Question No Grey Water Tank?????
There is an airstream that I'm looking at that does not have a grey water holding tank, the current owner says that you'd have to carry a portable. What does that mean exactly? Can I have a grey water holding tank installed? Is it costly? Is this common (for an Airstream not to have a grey water holding tank?)?
Any answers would help.
Thanks!!!!
Get rid of these ads... register today, it's FREE
Old 10-21-2002, 04:21 AM
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay, Florida
Talking
Welcome to the forum.
Here is a link to a thread that covers this.
Enjoy!. As much as you can enjoy thinking about grey water!!!
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
Old 10-21-2002, 07:52 AM
Pick
Pick's Avatar
Profile:  1972 31' Sovereign
High Springs, Florida
Lack of a grey water tank
I bought a 22 gallon "Blue" tank, available at any RV store. Not having a grey tank really is not a problem for us. If you have a full hookup site, it is not an issue at all. Last trip, I was camped in an apple orchard and just let it run on the ground. Until someone pitched a tent right at the back of the trailer.
CP 9 miles off Exit 399, I75.
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
Old 10-21-2002, 09:27 PM
JW84345
JW84345's Avatar
Profile:  1969 27' Overlander
, Michigan
1973 (or perhaps 4) were the first models with a grey tank.
I have a '69 Overlander. Not having the grey tank is a bit of a pain, especially when just stopping overnight, but manageable. We carry a blue tote tank for when we camp w/o hookups and I have a 5 gallon bucket I press into service for the quick overnights en route.
Another option some folks do is to mix black and grey with by putting a cap on the outlet and leaving the black dump valve open. I've never done this for two reasons. I haven't figured out how to deal with the water between the slide valve and outlet cover, and if the tank overflows .. it will back up into the tub. Draining it into the bucket works fine.
A good size grey tank in nice. My AS MH had 45 gallons each of grey and black. We could easily travel 3 full days without having to dump.
Old 10-22-2002, 09:14 AM
smily
"Still Working"
smily's Avatar
Profile:  North Charleston, South Carolina
Lightbulb Retrofit grey water tank
Has anyone ever retrofitted a grey water tank?
I have read the cons of the weight issue and I am aware of them but I cant help but think that someone has tried it.
I was thinking of a 4" PVC pipe that was strapped under the trailer and it ran the length of the trailer, (nominaly).
If a pipe of 4 " about 20 feet long were strapped to the under side it would hold quite a bit of water and to evenly distribute weight, one could install two lengths of pipe, one on each side.
I believe that this concept would work, a little jerry riggish but functional.
Of course the tanks would have to be emptied prior to leaving the campground or site or traveling on the highway.
Thoughts from the Gallery?
SMily
Old 10-22-2002, 09:20 AM
thenewkid64
Just a member
I have heard of someone doing this, but I have no idea how to calculate the useful volume of such a setup. I memory serves they used 2 or 3 inch pvc and zig-zaged it from side to side under the rear of the trailer. Not crossing the axel space. If a dumpstation is available where you are camping I would think it would be ok but I would not want to place that kind of additional stress on the frame while towing down the road.
Brett G
Old 10-22-2002, 10:15 AM
Silver Bullet
Silver Bullet's Avatar
Profile:
Here's another way....
I'm not sure who designed this (Grandfather or father) but both '62 Overlanders have the same set-up.
A 3.5" x 12" x 5.5' galvanized tank was fabricated at the local sheet metal shop. On the dump side of the TT a 1.25" valve was installed and a 5/8" inlet at the top edge. On the street side and on top was a 1/2" overflow tube. This was mounted underneath and in front of the rear bumper using 1/4" angle iron bolted to the frame, 4 bolts and 2 3/8" strap steel to serve as a u-bolt (so to speak) to hold the tank firmly against the frame. To get the grey water from TT to tank, a hose fitting was installed in the fry pan dump-valve lid. A piece of hose to connect the two and you got it. Tank (dry) weight was about 20lbs. give or take. If you empty it before hitting the road, water weight really isn't an issue. Back in the '60's and '70's alot of parks (State Parks in particular) didn't have sewer hook-ups and grey water on the ground was a big no-no. Oscar
Old 10-22-2002, 01:48 PM
smily
"Still Working"
smily's Avatar
Kinda boxy
I like the idea of the narrow box mounted to the rear bumper but iI think that if one were in a pinch to travel a little bit, the weight distribution would be better with the pipe idea(s).
Smily
Ken Smillie
My 1994 36' Classic MH is for sale
See it in the classifieds
Old 10-22-2002, 06:30 PM
Silver Bullet
Profile:
Smily.....
If either type you and I have described were empty while traveling I agree with weight issue. If either type had water in them while traveling (in a pinch) I would opt for the rear mount, the torsion bars on the hitch can adjust for the extra weight. The tank I described holds approx. 12.5 gals. (full), the 4" x 20' PVC tube holds 13.5 gals. x's two = 27 gals. of water and is mounted front to rear (direction of travel). Not a good thing if only half full. Moving liquid during acceleration and braking at a distance of 20' with no baffle system can get things a bit squirrley. Oscar
Old 10-22-2002, 06:44 PM
smily
"Still Working"
smily's Avatar
Lightbulb good point
I had not thought of the motion issue. You are absolutely right.
I was thinking that by spreading the weight would prevent a stress point but water moving around certainly has some energy to be reckoned with.
I will reconsider my plan, maybe with a crude baffle in place. The rear box seems to be a viable plan though.
thanks for the pointer,
Smily
Ken Smillie
Old 11-16-2002, 11:18 PM
eikel1we
eikel1we's Avatar
Profile:  1975 25' Tradewind
, middle of the mitt
I too have been thinking about the lack of a gray tank. This may sound stupid (I'm not exactly a stranger to that concept) but here goes ...... Is there not some way to use a "Y" to hook the gray water into the black water disposal line (refered to as the "poop shoot" around here) and into the sewer? Or maybe a "Y" at the sewer and two lines into that ? If you use a bucket or port-a-tank where would you dispose of that?
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
Old 11-17-2002, 12:15 AM
NewStreamer
NewStreamer's Avatar
Profile:
I am going to scrap the existing toilet seat assembly, seal the opening that goes to the black water tank.
Then I will buy the new Thetford toilet with removable black tank (not a porta-pottie)
in Europe 98% of RV's use this system. It looks just like the fixed unit as it is a fixed unit. You have a small outside access door to
get to the removable black water tank.
The Airstream's black water tank will then become a real grey water tank once you cap the exit and leave the now useless dump valve open.
You can see this toilet at the Thetforfd website. (the price in Europe is around 300$)
Et voila....
Ron
Old 11-17-2002, 06:58 AM
74Argosy24MH
Profile:  LOST, Hawaii
NewStreamer
Don't know about your TT, but the black tank in my MH extends well above the floor.
John
Old 11-17-2002, 09:06 AM
NewStreamer
Profile:
Before the grey tank era (73) Airstream documentation indicated this method .
I am only going one step further
Ron
vB code is On
Pingbacks are On
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 07:52 AM
Why not grey water into black tank? pilgrim_still Waste Systems, Tanks & Totes 40 10-08-2003 07:59 PM
Grey water tank for a 68 Globe Trotter Bryanhu Waste Systems, Tanks & Totes 5 06-26-2003 09:18 AM
grey water tank BIG question escapeez Waste Systems, Tanks & Totes 19 09-05-2002 06:52 AM
What Grey Water Tank?? niftypkg Waste Systems, Tanks & Totes 6 09-04-2002 07:12 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
