Old 05-15-2011, 04:24 PM   #1
tlsmit1's Avatar
1962 24' Tradewind
Saint Louis , MO
No black tank in 62 Tradewind
Doing a fairly extensive rehab on a 62 TW. The toilet, which seemed to be original, sat on a ~6-inch high platform on the rear curbside corner. The waste dump valve sat directly beneath the toilet. I had assumed (ha!) that the platform contained a black tank sitting on top of the frame or the plywood floor. But it turns out that there's no tank there--just empty space with a drain pipe going down vertically from the toilet outflow to the waste valve.
I've torn the whole business out now, and I need to figure out a way to put a toilet in that space. As far as I can figure, my options are to put a black tank on the floor with a toilet on top, or to install a Thetford cassette toilet. The cassette route looks simpler, but there doesn't seem to be a lot of experience with it on the forums.
Alternatively, does anybody have experience with putting in a tank above the floor, like this? How did you arrange things so that the weight of the toilet and a person were not borne by the tank? Or can I find a tank that's strong enough?
Other advice? Help?
tlsmit1 is offline   Reply With Quote
Old 05-15-2011, 04:53 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You would build a plywood frame with 1x2 reinforcement on the corners and bottom/top, mount the tank within, then cut a hole for the toilet to dump into the tank. You would need a tank that had 3 fittings spin welded into it. One threaded for the closet flange of the toilet, one flanged for the dump valve, and one 1 1/2" at the top in the corner for a vent.
Fresh Tank to Black Tank Flush (Spray) withidl Waste Systems, Tanks & Totes 19 05-23-2011 05:41 AM
Adding a larger grey tank to a 78 Tradewind johnhh Waste Systems, Tanks & Totes 3 04-04-2011 12:43 PM
'69 Globetrotter, Black tank for streetside bath dieselpup Waste Systems, Tanks & Totes 9 03-03-2011 06:50 AM
replacing black water tank in 68 Tradewind clydecrashcu Waste Systems, Tanks & Totes 1 01-17-2011 09:28 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
