01-16-2012, 03:57 PM
#21
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
To: Kamiak. Thanks again. One of these days I will need to be replacing the drain valves for my grey and black tanks. At that time it would be easy to convert my system to the valterra type. Is there any incentive to do that vs. simply leaving it alone and keeping the thetford system ?????
TO: Mr.Bill, From what I gather ( from discussion I read here ) the problem is with the "sludge" gathering along the way and not remaining in a solution that is easy to flush through the system. It sits, hardens and then fails to flow. By leaving it in the tank it has the time to liquify and flows properly when drained. I think that is why it is recommended not to leave it open to the drain. The grey tank is OK to let flow because there is no "sludge" issue there. But I would still leave the grey tank ( if present ) closed and drain it only when it is almost full. If you leave it open to flow you will not have the grey water to flush the hoses after the black water. And that would make the job nasty.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
01-16-2012, 04:58 PM
#22
2012 16' Sport
San Bernardino
Originally Posted by Mr.Bill
I don't have a trailer yet, so that puts me one step below newbie. Maybe this is a dumb question, but from looking at the many posts concerning toilet issues it seems to me that the minute that you put a toilet in a trailer you increase the maintenance issues about threefold. If your plan is to live in the trailer for weeks/months at a time it's worth it, but if you're only going to use the trailer a week at a time a few times per year it seems like you'd be better off just using the bathroom at the campground and not having to deal with having a toilet in the trailer.
AND - given that many owners may never camp in a location that doesn't have a sewer hook-up it seems like the standard trailer toilet set-up is backwards. Instead of having the toilet empty directly into the holding tank it should be connected to a pipe that leads to a Y-valve (like on a boat). Turn the valve one way and the sewage would flow to the black water tank, turn it the other way and it would flow directly out the pipe and into the campground sewer system, just like your toilet at home does. To my unschooled mind it looks like the current system is a holdover from when campgrounds didn't have sewers.
I used to have an old sailboat (27' Coronado) and the choices were: flush to the holding bag, dump in the ocean, or pump out at the station. When everything was in order it worked ok. I was always in a marina when not sailing, but waking up on those cold, cold windy nights made me glad the head was in working order. My first night in my 'Stream I didn't have sewer hooked up or water in the holding tank. The clubhouse was a long cold walk. I want to be able to make full use of the bathroom next time!
01-16-2012, 05:18 PM
#23
2011 23' FB International
2007 20' Safari
Irvine
Word of caution for folks who have sperate gray and black tanks. I would be careful for leaving the gray water valve open all the time when hooked up to the sewer, unless there is water seal in the hose (low point in hose where water fill the hose) there is a potential of sewer air backing up into the trailer. The best practice is to keep the valve closed and open when the tank needs to be emptied.
This is my opinion and I may be wrong
01-16-2012, 05:36 PM
#24
2006 19' Safari SE
Tucson
We usually do not leave our grey tank valve open when we have sewer hookups...mostly because I want to have some grey water to "rinse" out the hose after dumping the black tank.
That having been said, with an open grey valve, one should not get sewer gases coming back into the trailer if the p-traps in the kitchen, vanity and shower have water in them.
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
01-16-2012, 05:52 PM
#25
2012 16' Sport
San Bernardino
One more question...
First, thanks for all the good info here. I have one more dumb, dump question re dumping vs sewer hookup. I get the impression that when dumping to a dump tank you are just hanging the end of your hose into the tank after opening its lid, whereas an individual hookup allows you to actually connect. Is that true or am I missing something?
01-16-2012, 06:06 PM
#26
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Most sewer connections are just the hose inserted into a pipe. The collar should fit snug so as not to flop out and spill on the ground, but not always. I sometimes need to use a block of wood or a stone to assure the hose stays in place if the collar is a sloppy fit. Mostly it's not a problem just something to beware of. I've never had one that was a secure hook up. Many of the better dump stations have a foot operated flip lid that holds your elbow and is less likely to spill. It's not rocket science and after you do it you'll see what we have been saying. Get some good disposable gloves before you start. It's not a pleasant job but it is necessary and a little care will prevent it from being a real nasty job.
Roger in NJ
TAC - NJ 18
01-16-2012, 08:11 PM
#27
2006 19' Safari SE
Tucson
When we are dumping at a dump station, since it's very temporary, we usually just stick the end of the 3" dump hose into the 3"+ hole, make sure it's not going to get away from us using the cover or a rock (there are usually a few good-sized rocks there others have used) and let 'er rip.
However, when we have hookups at a campsite, we use a 90 degree elbow hooked to the end of the 3" hose and put that into the hole. (Pic #1) The elbow we have has several sizes of threading on it, so IF there are threads on dump hole pipe we screw it in...that assures that it doesn't get out and cause a mess. When there's just a hole and no thread, we still use the elbow, but do as Roger above does and stick the elbow into the hole and weight it down to secure it.
Some RV parks with hookups require that you have an airtight connection so that odors don't come out. There is a soft rubber/foam attachment that you can get to fit tightly into any hole when there aren't threads. (Pic #2)
I'd recommend getting a sewer hose support system (there are a couple of types) to help guide the hose to the dump hole on a downhill grade so that gravity can do its job. As we all know, s**t doesn't run uphill. (Pic #3)...
AirForums #21900
PastPrez, 4CU/WBCCI
01-17-2012, 08:44 AM
#28
2019 27' Flying Cloud
Albuquerque
, New Mexico
Threaded Elbow is Best...
...as illustrated beautifully above.
Thread it in.
Provide slope with a slinky as shown.
Keep black (main) valve closed until you are 3/4 full.
Keep gray (auxiliary) valve open until you anticipate a black water dump. Then, let the gray fill up a bit for a good, apres-black rinse.
Dump the black.
Then dump the gray.
Close your black valve.
Add 1/4 cup CampaChem* and 2 gal water through the toilet.**
Leave the gray water valve open.
Begin the cycle anew.
Sewer gas is not an issue if you have water in your P-traps.
We are living part-time in our Airstream here in Mesa, AZ and this system works great!
There's nothing like a good dump!
* I prefer the environmentally-destructive, formaldehyde-based brand; but it is prohibited in CA and some other states. It should not be used if you dump into a septic tank.
**Never leave your black tank completely empty.
Ken L 2019 Flying Cloud 27FB
2020 GMC Sierra 1500 Crew Cab 6.2L Max Tow Four Corners Unit WBCCI #5783
01-17-2012, 09:17 AM
#29
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Hi Ken. You mentioned above to never leave your black tank completely empty. I've never heard that before and wonder why ????? Once flushed and empty I can't see why not so please help me out. Mine has been empty since we parked it so hopefully things are OK. If it's somehow related to unpleasant odors we have none. I step inside every now and then just to look things over and observe no bathroom odors.
Roger in NJ
TAC - NJ 18
01-17-2012, 09:34 AM
#30
Albuquerque
, New Mexico
Never Say Never
When I clean mine out for long-term, winter storage,
After I have used a wand to really ensure it's clean, it's okay to leave it empty.
But I put a sign on the toilet to remind that it's winterized and not available for use.
During the camping season, it's best to leave a gallon or two of water with a cup of Campa-Chem in the black tank between uses for a couple reasons:
1.To prevent residues from solidifying into a build-up inside your tank.
2. So there is something in the tank in case you need to go when you are doing maintenance.
01-17-2012, 09:42 AM
#31
2012 16' Sport
San Bernardino
Thread it in.
Dump the black.
Then dump the gray.
I assume I turn on the water hose connected to the trailer flush port right after opening the dump valve? Or just after it stops draining on its own?
01-17-2012, 09:55 AM
#32
2011 28' International
Chatham
, Ontario
We learned quite a bit about waste tanks in our first year.
Firstly, there's a product called "RV Boss" which we put small amounts into both grey and black tanks and it really keeps the odours down. It's a natural, enzyme based product and we swear by it.
Secondly, we camped mostly at sites with no sewer hookup but with a dump station. In Canada, few dump stations appear to have a hose that's connectable to the on-board black tank flush system so a bucket of water down the toilet after using the dump station is a good idea to help prevent any solidifying.
Thirdly, stinky slinkys are not that bad, if you treat them with respect. Thorough rinsing after use and when dumping, keep your foot on the dump tank lid; the gloop can come out at quite a pace and make your slinky jump. It's not happened to me, I might add!
Fourthly, when using a full sewer hookup at your site, keeping both valves shut all the time seems to me to be a sensible solution. To go out daily and pull the valve is no big chore.
Fifthly (!), we found that a couple of sewer hookups at campgrounds were higher than our outlet pipe so wouldn't work. I guess you could get your trailer up on Lego blocks but I think a Sewer Solution or Flush King is a good think to have on board (says he who still hasn't bought one!)
Sixthly, we really could have done with sewer hose support on every occasion we used the full hookup. Santa was nice and brought us one.
Seventhly, when using a dump station, the thought of wearing flip flops might not be appealing in case of spillage accidents but remember, feet are easier to clean than shoes!
01-17-2012, 10:25 AM
#33
Chief Chili Cook
2010 30' Flying Cloud
Bakersfield
This seems like a good time to post the mandatory dump station disaster video.
The NSA -- The only part of the government that listens.
01-17-2012, 10:43 AM
#34
2003 22' International CCD
Kiln
, Mississippi
Sewer Solution has been mentioned here but I will 2nd its reference. You will not go back to a 3" hose after using one. I do carry a 10 foot section of 3' hose for an "emergency" dump if necessary, but after 2 years that has not happened.
BTW: that video above causes me to turn green............ I had a past experience with a hose clog - it was not pretty. I think that campground has my face pasted at the entrance to deny me access, forever.
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
01-17-2012, 12:53 PM
#35
retired USA/USAF
2001 30' Excella
Somerset
, New Jersey
Thanks Ken for the explaination. We're on the same wavelength. I thought there may have been a reason to leave liquid in there during storage.
Appreciate your willingness to share.
Roger in NJ
TAC - NJ 18
01-17-2012, 01:40 PM
#36
2006 22' International CCD
2007 Base Camp
Elk Valley
, British Columbia
Good thoughts, but an RV toilet doesn't use enough water to flush like a home toilet... which is also why the issues needing to manage extra water flow to clean them properly. You are spot on - for people with access to bathrooms, they will often use the RV toilet for night-time pees, and emergency poos... but use the site toilets for everything else.
It does seem ironic though, that some people essentially turn their Airstreams into an aluminum tent... and do nothing but sleep in them and use everything else outside.
Personally... I don't use the RV toilet any more than needed. I have a sensitive nose and even with odour blockers, I don't like the smell of an RV toilet. I specifically bought an FB design to avoid having the toilet next to the bed.
It's not rare to find used Airstreams with people proudly proclaiming they've never used the toilet or stove/oven... like mine when I bought it...
01-17-2012, 01:49 PM
#37
2007 Base Camp
Elk Valley
, British Columbia
It depends on how much you can manage on your own... my local sani-dump is set up so I can easily hold the flush hose and manage the slinky... there is nothing wrong with running it right from the start...
They are a neat idea, but I'm not sure the little spray thing in the tank is really doing a whole lot... RV tanks are so wide and flat that unless you had some kind of multi-headed high pressure contraption, they aren't ever going to be any cleaner than just filling them up with fresh water, going for a short trip to swish the tank around, and dumping.
I think people just get to get used to the idea that there will always be a certain amount of poo in the system, which is fine... it's not like it doubles as a hot tub or something...
01-17-2012, 02:15 PM
#38
Kiln
, Mississippi
Liquid Rid-X is much better at supplying the organisms in the tanks for digestion than most of the RV stuff. I add a "shot" and one gallon of water for the ride home and storage to keep things "loose" in there.
01-17-2012, 04:32 PM
#39
2012 25' FB Eddie Bauer
Virginia Beach
, Virginia
Sewer Solution
I've been fulltiming since 2005 and quickly got grossed out by the stinky slinky. The one the dealer supplied with the A/S was the cheapest possible model and quickly developed pinholes - like in six weeks. Buy top of the line if you choose a slinky - and know that the UV rays will require a replacement in a year or two if you camp a lot. Slinkies can fail with pinholes... or just split wide open. First trip out every season, watch with one hand on the dump valve and your eyes on the slinky!
*** there was an educational thread a couple of days ago that described a situation where only a slinky could solve a problem: You buy a used Airstream or have to be away from yours for months (illness perhaps) and find a black tank full of solidified poo where nothing comes out when you open the gate. A LONG slinky full of clean water, then lifted high can create enough back pressure to pop the poop plug loose. (In that case I'd want to keep the middle of the slinky high in the air while someone else got the elbow into the dump before dropping the middle and letting gravity do it's thing.) Duct taping a plastic bag over the elbow until it was safe to remove was also advocated.
The Sewer Solution WILL move water uphill (within reason) simply because the inside diameter of the hose is 1". The inside walls have no ridges like the slinky so there's nothing for paper, etc. to catch on.
You DO NOT actually need to use water to drain a tank with a Sewer Solution - most of the time. There is a water powered mascerator in the fitting that can bust up clumps of paper or biologicals. If you use resonable toilet paper (cheap stuff) that degrades quickly, and you've let the "stuff" in the black tank soften for 2-3 days, it will go down on it's own, followed by a water chaser via bucket down toilet, or use of the tank washer. There are no tank washers on the gray tank, so if it's getting funky or has just been a while, I'll fill both sinks and the shower pan with water, then whoosh out the gray tank after it's drained to get the hair, soap, grease and general crud out of it. Prior posters are correct, it can smell nearly as bad as the black tank. I also use Rid-X - it's much cheaper than the equivalent RV chemicals and has the same enzymes.
If your kid flushes the Barbie doll's head down the toilet, or you have guests, assume they are ignorant and explain very frankly why disposable feminine hygiene supplies, condoms, disposable diapers, paper towels, cigarette butts, etc. cannot go down the toilet. Have a spring top trash can with bags, etc. for unmentionables, and get rid of them daily. NEVER invite guests back if you later find evidence that they "forgot" and flushed something inappropriate!
The mascerator would probably take care of everything but the Barbie Doll head or a tampon. (I actually saw someone find a Barbie head in their slinky. The son "the perp" thought it was funny, the daughter will need therapy!)
I did let company use my trailer for a week while I was traveling - a "captain's log" definitely needed masceration. Gotta get that kid on some more high fiber food!
happy trails, Paula
01-17-2012, 04:42 PM
#40
Virginia Beach
, Virginia
Toilet Paper test
Quart jar of cold water - two sheets of your chosen brand of buttwipe. Drop in jar, secure lid, shake for 15-30 seconds. Observe your "snowglobe". Choose one that you like that does break into many many pieces - but not while you're using it.
You'll find that some NON RV brands perform as well or better than the higher priced specialty RV papers.
Avoid anything that says "extra strength" or that contain "lotion" - last thing you need is a grease slick in your black tank.
On a related note, I bought one treatment of an orange scented chemical that "guaranteed" absolutely no odor - odors would be sealed under a layer of orange scented oil.... It worked perfectly BUT every sheet of toilet paper that hit the oil slick was transformed into a leathery sheet that would NOT break up without mascerating it. Not thrilled to spend 45 minutes dumping the black tank.
Paula
