Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 01-16-2008, 05:56 PM   #1
2001 19' Bambi
Ashland , Oregon
New to camping and 'black water' tanks
We bought our 2002 19' Bambi in October and have yet to take it out. I want to be fully informed about as much as possible before we go out. Even then we're sure to make a boo-boo or two (or three, or four, or...).
A friend of mine said not to use the loo for number two. Sounds reasonable enough only it got me wondering. Conventional wisdom says the black tank should be half full before dumping it. With just two of us camping, that could take awhile. Could we put water in it to bring it up to being half full? Would that be sufficient for draining the tank?
Muddy Waters is offline   Reply With Quote
Old 01-16-2008, 06:04 PM   #2
Naples , Florida
Black tank etiquette
Great name! Hope you enjoy his music too!!!!
Anyway, I'm afraid that your friend is passing along another 'old wives' tale (sorry girls ) about the black tank. Why do you think that Airstream included one with your trailer? To begin, after you dump your black tank and rinse it thoroughly, you should add a gallon or 2 of fresh water, then add a tank deoderizer/enzyme to it. USE IT, THAT'S WHAT YOU HAVE IT FOR!!!!!!!
When it's at least 3/4 full, dump it, rinse and repeat the above process. You don't dump it with less than 3/4 load because the extra liquids in the tank help to wash down any solids that are there.
NEVER LEAVE THE BLACK TANK VALVE OPEN!!!!!!!!! This will drain all of the liquids from the tank and leave the solids in the tank.....resulting in a condition commonly referred to as 'the black hills'.
Any Questions?
lewster
Old 01-16-2008, 06:09 PM   #3
cosmotini's Avatar
2021 27' Globetrotter
Saint Louis , Missouri
Images: 83
I flush the black tank when it's at least 3/4 full. If it's not then I'll just flush until it is.
There is no reason NOT to do #2 in your loo. If you start with 4 or 5 gallons of water in your black tank, the solids will be suspended and/or break apart much better and using the 3/4 full rule will provide enough volume to move the solids out.
Dennis
BRN #20321 Air #4056
"Oooh - They have the Internet on computers now!" - Homer Simpson
cosmotini is offline   Reply With Quote
Old 01-16-2008, 09:38 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We usually don't make it to 3/4 full in the black water tank since it's just the 2 of us...but we don't want to haul that around with us either, so we dump when we leave the park (assuming there's a dump station or hook-up, of course!)...BUT you do need to make sure it's flushed out well...we have a built-in sprayer thing that we use to fill and flush the tank once we have done the initial dump...just to make sure it's as cleaned out as possible. If you don't have a built-in sprayer/flush system, then you can just add fresh water to the tank by filling the toilet bowl and flushing repeatedly. Then dump it again.
And don't be afraid to use the toidy for #2...that's what it's there for! It's perfectly OK to do.
The whole black tank thing is probably the most worried-over aspect of RVing for those new to it, but frankly, once you've done it a couple of times the mystery and fear is over...it's not that bad.
Enjoy your new Bambi! Time to get it out on the road!
We'll see you there!
TB
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 01-17-2008, 11:15 AM   #5
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
And dump your black tank first, then the grey tank. Your grey water will "clean" out your slinky.
Do a search on this subject, there are more posts then you will want to read. Which means that you are not alone, this is a common question.
Dave
Fyrzowt is offline   Reply With Quote
Old 01-17-2008, 11:39 AM   #6
Silver Condo III
kamadeca's Avatar
2015 30' International
Saskatoon , Saskatchewan
Thought I would wade into this discussion. Being the proud owner of a 25 SS, putting in 4-5 gallons of water in the black tank means that I have now used almost a third of its capacity (18 gals). We generally only put a couple of flushes to start plus enzyme. We always make sure it is at least 3/4 full before we flush, and if it isn't top it up with water.
We have had no problems in the 5 years that we have owned the trailer.
Happy flushing
Malcolm & Randy
WBCCI # 12523
kamadeca is offline   Reply With Quote
Old 01-17-2008, 02:02 PM   #7
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Muddy Waters, welcome aboard! My fellow members have got it right for you on using your black tank. You didn't pay for it to just sit there nice and clean ALL the time. One of the many, many great joys in camping with your AS is that you get to sleep in your own bed and have your own privey. Use it well, keep it clean and all will be right with the world!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 03-22-2008, 01:22 AM   #8
MG911's Avatar
2005 28' Safari
Saskatoon , Sk.
Sorry this post is a bit late but I've had the winter blues and now that the snow is melting...it's time to get revved about 'streamin again.
On a side note..do any of your electronic black water gauges actually work? I have an '05 Safari and have yet to see it give accurate readings. It usually flashes red indicating it's 'full'. Just a thought...
MG911 is offline   Reply With Quote
Old 03-22-2008, 04:08 AM   #9
olddog299's Avatar
1990 25' Excella
Glenburn , Maine
You just might have a malfunctioning gauge there, MG. First, I'd try "scouring" the b/w tank with a 25 lb. bag of ice cubes, 3 or 4 gallons of water and a nice little trip through the neighborhood practicing turns without cutting over curbs -- just agitate that puppy to a fare-thee-well! Then dump and repeat on the way home. See if that doesn't clean off the crud on the sending unit (and the rest of the tank's walls, too).
If no luck, then as my 8 y.o. grandson is so fond of saying, "Sucks to be you." What with the warranty runout and all. Either make do, make a story stick out of a wooden dowel kept for the purpose, or pay to have it replaced.
As in all Airstream endeavors -- good luck!
wil
AIR 22828
TAC ME-3
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 03-22-2008, 07:14 AM   #10
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
You certainly CAN use it anyway you want (and I do personally know one or two Airstreamers who "don't do the two"), but it was designed to be used like a regular bathroom.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 03-22-2008, 08:32 AM   #11
1986 31' Sovereign
Miami , Florida
An interesting short read on things Sewerish...
Macerators and Other Sewage Stuff by phred
We use the methods and products the author recommends and we have had (knock on wood) zero problems in 12 months of camping over the last two years.
mike
Old 03-22-2008, 08:39 AM   #12
Hondo was a great cat
jnerges's Avatar
2005 28' International CCD
Salt Lake City , Utah
The Black Water Tank is a miracle (About the ice)
Hi All,
Frankly I am still amazed that the ancient Romans invented plumbing in the first place. Thank God since it created an entire industry.
My Black Water gauge seemed squirrelly and I did the ICE in the pooper drive around thing over bumps and dump at the rest stop on I 5 thing. It worked great.
John
Aunt Gladys, 28FT, Intl'
"Man, it's hot here, is the heat on?"
jnerges is offline   Reply With Quote
Old 03-23-2008, 11:07 PM   #13
MG911's Avatar
2005 28' Safari
Saskatoon , Sk.
Ya, I've heard about the ice trick..will have to give it a try this time. The Safari I have supposedly has a good rinse system but it hasn't been enough to clear the sensor of any debris (aka poop). Either that, or it's a faulty sensor. Thanks for the tips.
Old 03-24-2008, 06:22 AM   #14
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Detergent
A SMALL amount of dishwashing detergent in addition to the ice cubes will also work wonders on the sensors.
Oh yes, DO make sure your grand nephew doesn't flush three hot wheels down the toilet. (Don't ask). I'm sure in a couple of years it will be the heads of decapitated Barbie Dolls.
I've lent my Airstreams to relatives and friends who aren't into the RV scene on more than one occasion. One does have to be quite SPECIFIC about what does NOT go down a black tank. The best explanation without being too graphic is "if it wasn't created within your body, or it doesn't come off of that toilet paper roll, it doesn't get flushed."
I do have one in-law who is irritatingly dense who insisted that flushing certain feminine hygiene products would be OK, because the box said so. I explained it nicely, but the cow still flushed everything. Thank goodness I had an old slinky, which I threw away after I'd gotten the tank EMPTY. That was a real treat involving running the curbside wheels up on four inches of boards to get an incline sufficient to move the products.) When she hinted that they'd be coming to visit this weekend, I told them they'd need to get a hotel - and told them exactly why.
If you have guests, do make sure there is a small lidded waste basket with plenty disposable liners available.
Paula
Old 03-24-2008, 07:02 AM   #15
yukionna's Avatar
Massachusetts
Images: 18
I don't have that problem because I don't usually lend out my trailer, not even to family.
I have lent it out twice to Airstreaming friends who recently stopped towing. No worries there, because they already know the drill!
WBCCI Region One
Old 03-24-2008, 10:07 PM   #16
MG911's Avatar
2005 28' Safari
Saskatoon , Sk.
I happened to be speaking with my AS service centre on a separate issue and just happened to mention the gauge not reading properly. He stated it's not actually a probe that reads the liquid levels in the tanks but it's measured by weight. Does this sound right?? I was under the impression it was more than likely a probe that was covered with foreign material causing the incorrect readings...hmmmm....
Old 03-24-2008, 10:29 PM   #17
2005 25' International CCD
1954 22' Flying Cloud
1957 22' Flying Cloud
Simi Valley , California
it's not weight... unless you're sitting on the throne... after a 5 lb deposit, my gauge doesn't even budge... i'll eat 10 lbs of ice and see if i can get the gauge to move then... k.
Kevbo10 is offline   Reply With Quote
Old 03-24-2008, 10:34 PM   #18
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Sounds like a sales person talking. The factory black tank flush is marginal at best. Ice cubes and water along with a flush king are your friends.
Michelle TAC MT-0
Sarah, Snowball
Old 03-25-2008, 06:45 AM   #19
yukionna's Avatar
Massachusetts
Images: 18
By weight???
I never heard that one before. Hmmmmm...I think we need some cross-verification here!
My evidence to add to this thread...
When my tank is full on the 2002 Bambi, it reads full.
Immediately after I dump, flush, dump, flush, dump, flush, it reads 1/4 full.
Then, if I don't use the trailer for a few weeks and go back in and read the gauge, it reads as empty!
Because of that, I always thought the gauge was wet after the dump, so it never registered as empty. So, my logical reasoning after that is after a few weeks of no use, the gauge had time to dry off so then it reads empty.
Very curious mystery we have going here.
WBCCI Region One
Old 03-25-2008, 07:27 AM   #20
jnerges's Avatar
What we need is
We need a brave person to shrink themselves down, get in a space ship and fly around in there to see what really goes on, then they could fly around the fridge to make sure the light really goes out. Let's see, this plan could come in handy, where else could we send miniaturized Airstreamers???
Black/Grey water tanks 1968 Overlander StuartM Waste Systems, Tanks & Totes 4 03-22-2007 06:43 PM
Need help removing black/grey tanks baseballmamm Waste Systems, Tanks & Totes 2 08-13-2005 09:15 PM
Why aren't the grey and black holding tanks one? Kistler Waste Systems, Tanks & Totes 26 06-02-2004 03:41 PM
How to get at Black and Grey tanks... xtrm69 Our Community 7 01-30-2003 05:28 AM
