Old 12-04-2006, 08:52 AM   #1
Petethefeet's Avatar
1964 30' Sovereign
1959 22' Flying Cloud
1957 26' Overlander
Raglan , New Zealand
Images: 14
New tank location
Hi, I have a 64' Sovereign, undergoing a ground up restoration/retrofit. It has reached a stage where a decision needs to be made about the water tanks. There will be a fresh water tank and a grey water tank. At this stage, the toilet is to be a cassette type. Does anyone have any helpful advice to share on where a good practical place to put these tanks. I am musing of getting custom made tanks to put within the floor space near the axles. Is this a good idea? Is it practical?
Thanks heaps,
Pete
Petethefeet is offline   Reply With Quote
Old 12-04-2006, 09:09 AM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Greeting Peter-
I wish you all the best with your restoration. What size is your trailer? I am in the middle of designing a restoration on a vintage and right now I am working on three tanks, fresh, grey and black in a trailer that never had a grey. With limited space between frame rails I am planning at putting the fresh water tank under the bed on top of the floor and the grey and black within the frame work. Keep th trailer balanced is critical when deciding where to place things. Once you have an idea od LP tanks and fresh water you want the grey to be as close to the axle as possible but at the same time in a position to keep the unit balanced.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 12-04-2006, 12:48 PM   #3
1964 30' Sovereign
1957 26' Overlander
Images: 14
Thanks for that, the sovereign is 30', and she looks better everyday. I did wonder about the balance, and considered putting smaller tanks fore and aft of the axles, and coupling them. I understand they would need to be vented separately. Do you know if vent pipes can run horizontally for a lenth? And what about you, what sort of Airstream are you bringing back from the brink.
Regards,
Pete
1978 Minuet 6.0 Metre Gray Water Tank overlander64 All Argosy Trailers 6 11-15-2002 06:11 AM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
63' tradewinds black water tank Pberrini Waste Systems, Tanks & Totes 1 09-22-2002 12:57 PM
Water Tank Pan Craig Fresh Water Systems 7 09-06-2002 08:52 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
