Old 01-30-2011, 01:38 AM   #1
Mexray's Avatar
1978 28' Ambassador
Morada , California
New Slant on Tank Sensor Cleaning...
I found this info buried in an RV'ers blog the other day...Haven't tried it yet, but it sounds plausible...
Try this method of Gray & Black tank sensor cleaning when your rig is going to be at rest or in storage for about a month in ABOVE freezing weather:
1. Empty both holding tanks.
2. Add about 1/2 cup of liquid Septic Tank Enzyme Additive, the type that's safe for plastic tanks - to each holding tank.
3. Fill each tank about 1/2 full with fresh water.
4. Take a drive around the neighborhood to get the 'brew' well mixed.
5. Return to your storage area and add enough water to fill each tank completely.
6. Let it sit for a month to allow the enzymes to work on all the 'crud' inside, before flushing with fresh water.
If anyone's used this method, let us know how you felt it worked out...
Ray & Pat; Morada, CA
Old 01-30-2011, 07:02 AM   #2
knunut's Avatar
2007 20' Safari
2016 26' Flying Cloud
Chgo. N.W. Burb's , Illinois
Clean Tank/Sensors
Thank's for info. Sounds like a good idea.
knunut is offline   Reply With Quote
Old 01-30-2011, 10:18 AM   #3
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Tank Sensors
What would camping be if you knew everything was working perfectly?
You just can't beat the excitment of the moment, when the grey water backs up into the shower, or your loving wife just gets the shampoo on her hair and you run out of fresh water!!!!!!!!!!!!
These are truly the "MOMENTS TO REMEMBER"
Campfire Stories don't come easy when all systems work as planned.
Dave
Old 01-30-2011, 10:28 AM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Sounds like a decent idea - most of us worry about the black tank, but the gray tank gets a lotta nasty stuff in it too! Just think about washing dishes and showering.
FUNKY.
I'd personally bet that a couple of days would do the trick.
Paula
Old 01-30-2011, 11:51 AM   #5
SteveH's Avatar
Common Sense , Texas
I think I'll give it a try. We've had several Airstreams (never bought a new one) and never had tank guages that actually worked.
Regards,
Steve
Old 01-30-2011, 01:07 PM   #6
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Any excuse to hitch up is a good one.
tank cleaning
Old Water Tank Removal & Clean up IronGiant Fresh Water Systems 9 06-23-2011 07:53 AM
Pex for fresh tank outlet DanielB Fresh Water Systems 12 01-23-2011 04:10 PM
Fresh water tank relief valve "bumps" above floor? DanielB Fresh Water Systems 12 01-19-2011 06:00 PM
replacing black water tank in 68 Tradewind clydecrashcu Waste Systems, Tanks & Totes 1 01-17-2011 09:28 PM
Extra 67 tradewind blackwater tank, gray water tank poezlaw Waste Systems, Tanks & Totes 0 01-17-2011 09:19 PM
