Old 01-14-2006, 08:03 AM   #1
1972 27' Overlander
Lafayette , Louisiana
new owner '72 overlander
HI Folks, Well I did it, I bought my first Aistream. Now I am finding all the wrinkles that were not apparent on E-bay.
My first question. OK the 72 overlander does not have a grey water tank and the water just seems to flow out from the belly skin at the rear seam. So, before I remove the rear belly skin, what is the normal fix for this situation?I don't have a 72 schematic, just a 74 that came with the trailer which is different.
second question, previous owners wanted a bigger battery, so they installed it on the floor of the pantry cupboard next to the fridge. For rechargeing, they had a charger hooked up to the fuse box, too wierd for me so i removed that. Any insight and advice to this situation would be appreciated. Now that I am part of the Airstream family should I join a club, learn a new handshake, sacrafice a few rivets? I wanna be cool too!
Tim
TimM is offline   Reply With Quote
Old 01-14-2006, 08:46 AM   #2
vajeep's Avatar
1976 27' Overlander
Richmond , Virginia
Images: 49
Welcome Tim
Hey Tim,
Welcome!! We have a 1976 Overlander... As far as the water leak.. this is not normal The forum is a great place to learn and share. As far as the hand shake... I am still trying to learn...
"Abe" & Melissa Lincoln
1976 Overlander "Spirit"
2005 Suburban w/q-steer
Hensley Hitch
vajeep is offline   Reply With Quote
Old 01-14-2006, 09:42 AM   #3
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
You are too funny. You will do well in the Aristream/Argosy family. Most of us don't dare shake hands since we usually have renovation stuff all over them. Right now I'm covered with paint from my toilet refinishing work. Maybe that's the secret. To be a member you have to have goop in your hair, on your shirt and under your finger nails. Welcome to the club. It's fun in here.
juel is offline   Reply With Quote
Old 01-15-2006, 05:07 AM   #4
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
Better charge up the drill
Tim,
Welcome to the wonderful world of 30+ year old airstreams. No special handshakes here, just a lot of drilled out rivets and Vulkem stained hands.
I refer you to a thread from a similar new owner a few months back. I listed a few things with links to some pics.
I recommend a complete belly pan removal (in the rear, anyway) for a thorough inpection. The gray water (from kitchen sink, tub, and lavatory) drains out through the streetside waste hook up. Water exiting from the the belly pan could be from the tub P-trap (below the floor), cracked or loose drain plumbing, or more likely from supply/water heater leaks.
Good luck!
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 01-15-2006, 05:43 AM   #5
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Welcome to the adiction, Water from anywhere ither than the drains is not normal. Look dor the discharge hook up.... May have a cracked waste pipe or open valve. Post pics if you can?
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 01-15-2006, 08:52 AM   #6
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
another tim with a '72 27-footer
hey tim- yeah, what pizzachop said: you should drop the belly-pan, at LEAST in the rear, to see where your leak is coming from. You will be very lucky if you have no rotten plywood subfloor in the bathroom, mine was bad all around the tub drain and rear perimeter. I've got my fingers crossed for you, as otherwise you're looking at gutting at least the bathroom to replace the subfloor. I think you'll want to get the Airstream Service Manual, available often on ebay, or from: Secretarial Services, box 484, Sidney, Ohio, 45365. Phone: 937-492-8885. The battery is more typically located inside a rear hatch, under your tub. Next to it is the univolt, which typically no longer works properly. I have a thread on my repairs you can look at. Best of luck in your searches, tim
tphan is offline   Reply With Quote
Old 01-18-2006, 10:48 AM   #7
1972 27' Overlander
Many thanks
I appreciate all your replys and now have an idea of what to do, or at least where to start. Thanks I will try to take pics and post progress. peace.
Old 01-18-2006, 10:50 AM   #8
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
Congratulations on the new coach!
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 05-24-2006, 12:30 AM   #9
RoadRunner
1972 27' Overlander
Hattiesburg , Mississippi
Smile '72 Owner's Manual
Hey Tim,
I purchased my 72 Overlander a couple of months ago and was concerned about not having manuals, but to my surprise (and relief) I found not only the owner's manual but also the service/maintenance manual, all of the papers for the a/c, toilet, water heater and furnace. The furnace that originally came with my unit was recalled in 1990-something so there is an even newer furnace installed. I found the recall letter along with some old campground brochures and even the Wally Byam Store accessory catalog for 1972. Man, I wish I could still order from it.
Anyway, I am working on similar plumbing issues and I'm considering adding a gray tank. I would be happy to send you a copy of my manuals if you are interested. I plan on making a copy for myself to use and preserve the originals. Send me an email rcloeffler@netzero.net and we'll connect.
Regards,
Roy
rcloeffler is offline   Reply With Quote
New Owner "ALMOST" JLD 1974 - 1979 Sovereign 2 01-01-2007 06:57 AM
1966 Overlander International Double Tamara 1966 Overlander 30 03-28-2006 02:55 PM
PROUD NEW OWNERS of a 1974 International Overlander Anna Our Community 6 11-09-2002 07:29 PM
tree on '69 Overlander pebblepoint General Repair Forum 2 09-10-2002 06:01 AM
Looking at a '64 Overlander N80 1960 - 1964 Overlander 1 06-02-2002 08:25 PM
