Old 08-23-2011, 07:42 PM   #15
Lyle & Margie
2008 28' International CCD
Lakeside , California
WWDave:
FYI, our 2008 28' international is plumed the same as your 30'. I think our floor plans are the same (except yours is a bit longer). Is you bath sink about 3 to 4 ft from the toilet?
Lyle & Margie
BAB BMRZ is offline   Reply With Quote
Old 08-24-2011, 01:18 PM   #16
2006 28' International CCD
Nashville , Tennessee
I can't understand why this is such a problem. In our home bathrooms (and all others) doesn't the sink/shower water drain into the same place that the toilet does?
Debbie
dmoore is offline   Reply With Quote
Old 08-24-2011, 02:06 PM   #17
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Debbie
Yes, but not into a holding tank. A permanent structure is hooked to a public sewer system or a septic tank. All waste drains into the same place, but it goes away, usually never to be heard from again.
In an RV, normally the toilet drains into the "black" tank, and the sinks and shower drain into a "gray" tank. In the old days, gray water was allowed to simply drain onto the ground, and RVs didn't have gray tanks.
Knowing what drains where is important, so one does not overfill a holding tank and have used water showing up in the living space floor or shower.
If you think all the sinks are going to the gray tank and have it hooked to a dump site with the valve open, you can assume all the water you are using is running out as fast as you run it in. But, if said sink is filling the black tank and not leaving the trailer, in a little while you will have a stinky problem running over the top of the toilet.
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 08-24-2011, 02:18 PM   #18
Gainesville , Florida
Buyers remorse, jim
