Old 09-20-2015, 05:21 PM   #1
1968 24' Tradewind
cloverdale , British Columbia
New Holding Tanks
Im planning on having new black and grey water tanks made up and was wondering if putting the drains on the bottom f the tanks is a bad/good idea? Any thoughts?
cregu1 is offline   Reply With Quote
Old 09-20-2015, 06:22 PM   #2
robwok's Avatar
1964 26' Overlander
Richmond , Virginia
Images: 35
Drains on the bottom are preferred, as they allow you to drain out all the way, but you'll have to have the connections lower than the tanks. a lot of the newer ones are that way. If you pull out of the side, you can't drain all the way, but I will say that it's really tough to snake everything through. I did it on my 64, but not sure how deep the frame is on the 68.
robwok is offline   Reply With Quote
Old 09-20-2015, 08:21 PM   #3
1979 23' Safari
Wayland , New York
You run into issues with how far down the drains will have to project. The frame's only about 5" deep, so any below that and you'll be projecting into dangerous territory.
HiJoeSilver is online now   Reply With Quote
New Holding Tanks cregu1 LP Gas, Piping, Tanks & Regulators 2 09-27-2015 04:41 PM
Replacing water tanks, holding tanks & battery? AussieGirl 1956 - 1959 Flying Cloud 57 10-19-2014 08:21 AM
Holding tanks gage is there a key or plugin to test the levels of the tanks. Buckshot 1999 Safari 1 08-18-2014 08:25 PM
Mounting New Holding Tanks dbj216 Waste Systems, Tanks & Totes 7 01-21-2014 06:28 PM
New holding tanks & monitor Sys VeggieBullet Fresh Water Systems 3 10-27-2011 07:50 PM
