Old 07-27-2016, 03:26 PM   #1
1976 31' Sovereign
Utica , Ohio
new black and gray tanks 1976 31 ft
With the help of the forum I am still working on a shell off project, new frame and floor complete. Looking to find larger black and gray tanks. My question is what have experiences been locating tanks, which companies good to work with and lastly any one installed tank fittings using the rubber grommets instead of spin fittings. success rate? all feed back appreciated.
SILVER BEE is offline   Reply With Quote
Old 07-27-2016, 04:06 PM   #2
Hittenstiehl's Avatar
1965 24' Tradewind
1962 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
VTS
Plastic-mart
Inca
Inland RV
Come to mind,
Google "Plastic tanks for Airstreams"
Then Google " Airforums plastic tanks for Airstreams "
Both will get you some neat images of various shaped tanks and positions.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 02-28-2017, 06:56 AM   #3
1976 29' Ambassador
Dallas , Texas
Hi Silver Bee what approach did you go with? How did it turn out!
tabney0315 is offline   Reply With Quote
Old 02-28-2017, 08:42 AM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I got mine through Vintage Trailer Supply. It was made by Inca. It was less expensive than through Inland RV
Lumatic is online now   Reply With Quote
Old 02-28-2017, 08:44 AM   #5
1976 29' Ambassador
Dallas , Texas
Thanks. Did you go with the rubber grommets or get spin fittings?
Old 02-28-2017, 08:54 AM   #6
Lumatic's Avatar
1993 34' Excella
Images: 16
This was a black water tank on a 71. It was identical to the original with Thetford screw in fittings. Black Polyethylene instead of clear. I did have the option of going with Valtera but chose Thetford because I had a new Thetford dump valve.
Old 03-18-2017, 12:48 PM   #7
1976 31' Sovereign
Utica , Ohio
went with two tanks from inca, great service and support. each tank approx 40 gal
Old 03-18-2017, 12:54 PM   #8
1976 31' Sovereign
Utica , Ohio
i used rubber fittings on the new tanks and made my own spin fitting tool and added a drain to my existing fresh water tank. rigged a tool using a router and a socket. be sure to balance rig and use arbor large enough to handle initial start up torque. bounced a couple of sockets off wall till i got i right.
Want to add new black and gray tanks DDickey Waste Systems, Tanks & Totes 6 05-27-2016 08:49 PM
Attaching new flanges to gray and black tanks? jasper2222 Waste Systems, Tanks & Totes 1 07-19-2010 09:17 AM
Black and Gray water tanks NavyDavesCvl 1965 Caravel 4 03-20-2010 09:21 AM
'59 Tradewind I need new black and gray tanks tomsdayoff 1959-69 Tradewind 28 05-06-2008 10:31 PM
Anyone have any luck putting Gray and black tanks in a 63 tradewind??? durans54 Waste Systems, Tanks & Totes 1 12-05-2006 08:56 PM
