Old 06-03-2008, 03:56 PM   #15
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Reminds me of my encounter last fall.....For those of you new to the Forum.
http://www.airforums.com/forums/f239...ler-37085.html
Jack
Jack Canavera
STL Mo.
AIR #56
Old 06-03-2008, 05:59 PM   #16
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
I'm confused as how anything droped into the tank could prevent opening a gate valve. If it were a problem with closing the valve then I could under stand. Can anyone help me here?
Pop Rivet is offline   Reply With Quote
Old 06-03-2008, 06:06 PM   #17
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I'm with you. Nothing, except maybe a large volumn of epoxy, dropped into the tank should hinder opening the gate valve.
Old 06-04-2008, 05:49 AM   #18
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Originally Posted by ArtStream View Post
For peat's sake, buy a new electric toothbrush.
Problem is that on some 25ers, the PVC bend will capture the electric toothbrush, blocking the emptying of the tank.
Once you find it, or even if you don't, take a shop vac, shove the hose into the tank from the head, and fish it around in there. As long as you have a good vac the suction could grab it and if not ingest it and pull it into the vac, at least bring it closer to the entry point of the head to grab it some way. I would try this before yanking the tank. You'd be surprised at what a good shop vac can pickup. I have one from Sears and although I've never attempted this type of use with it, I would think this might work given some of the things it's caught just doing normal vacuuming around the garage. I used it to clean out some junk children threw in an HVAC vent at the house. Unreal what it pulled out of the vent.
Old 06-05-2008, 01:56 PM   #19
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
If you take SILVERTWINKIE'S method, be sure to get a new filter for that shop vac
So, what is the progress? What worked?
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 06-05-2008, 02:15 PM   #20
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
I think Silvertwinkies idea is a good one. I've used my shop vac to get stuff out of some really awkward places. It can be messy for sure but very worth a try.
Your best bet though it to borrow a friends shop vac as yours must be "broken".
Barry
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 06-05-2008, 05:55 PM   #21
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Rivet Funny
Barry
Hi Barry,
Got a laugh from your suggestion. Karma sent, but accidently clicked add before adding a comment.
Still, not absolutely sure your comment should be sent Karma.
Vaughan
vswingfield is online now   Reply With Quote
Old 06-05-2008, 07:37 PM   #22
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Well, did you ever get the toothbrush out???
Judy At Home in Oklahoma
juel is offline   Reply With Quote
Old 06-06-2008, 10:44 PM   #23
safari57's Avatar
1960 24' Tradewind
West Coast , BC
Originally Posted by vswingfield View Post
Hi Barry,
Thanks Vaughan -
I guess the one person who'd think my comment "sucked" would be the loaner friend....
Barry
Barry & Donna
Toothbrush Disappears in Toilet!! HELP! Becky B. Sinks, Showers & Toilets 68 08-10-2010 08:01 PM
For electric for genration hase to be oun for electric RichardT Electrical - Systems, Generators, Batteries & Solar 7 12-05-2005 08:05 PM
electric brakes Al1 Brakes & Brake Controllers 16 02-08-2005 07:59 PM
Electric or Gas electric fridge replacement?? tin can luv Refrigerators 26 03-22-2004 09:50 AM
Electric rslaymaker 1965 Safari 2 05-29-2002 10:46 PM
