Old 04-20-2007, 10:07 PM   #15
a.k.a. Ambassador Tim
Safari Tim's Avatar
1960 28' Ambassador
Northern , California
Images: 35
Got 'er done!
I actually got the job done.
The problem was two fold. One the original hole in the frame did not allow the 90 ABS elbow to fit. So I decided to use my dremal grinder and have at it. Only needed about 1/16" anyway on both sides.
The second problem was there was not enough room to make a U back into the side of the dump assembly. Two standard 90's back to back was a half pipe wide to big. To *vent* 90's would have worked. But I ended up finding a U trap that was perfect. So it looped it right into the 1.5" grey valve.
In the end I have a modern dump system. One hose connection, one 3" black straight down, and one 1.5" grey.
Only thing I don't like is it all terminates on the curb side rear since thats where the black tank was. So hooking up to the campground sewer will be a job everytime.
ID:	35925   Click image for larger version
-Tim
theVAP - Airstream Podcast
Old 04-20-2007, 10:25 PM   #16
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Wow, that looks good Tim. Having to deal with the drain on the door side of the trailer can be a pain but you've got the major problem solved and you can at least use the bathroom again.
Appreciate the update, and the pictures helps put it all in perspective.
Barry
safari57 is offline   Reply With Quote
Old 04-20-2007, 10:31 PM   #17
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
Thanks Barry,
One last important item I forgot. It was critical to keep it as close to the bellypan as possible since the tail end gets really low backing up inclines. Like my driveway.
So it looks like just the part the hose attaches two will be sticking out of the belly. Can't ask for closer than that!
-Tim
Old 04-21-2007, 06:25 AM   #18
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Tim, looks like you have the great dump valve caper under control.
I do have a suggestion to help you dump...
I mentioned before PVC is cheap, why not run a hunk of PVC pipe across the back of the trailer to dump on the street side of the trailer? You can hook up the slinky over there, come back and dump black and grey, then go back and unhook the slinky. This will keep your feet away from the slinky if it accidentally blows off the pipe as well.
Old 04-21-2007, 10:40 AM   #19
Safari Tim's Avatar
1960 28' Ambassador
Images: 35
I really didn't want any plumbing running below the bellypan. One for looks but the other for the clearance issues.
It should be just a matter of using a 45 on the dump connection and laying a hose on the gournd the width of trailer to the street side.
-Tim
Old 04-21-2007, 10:44 AM   #20
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
I have 2 - 10' slinkys connected together which barely fits/stores in the tube below the trailer. It is long enough for those unusual campsite arangements and will easily reach to the curbside.
Dave
Fyrzowt is offline   Reply With Quote
low drain points Raptorrider2001 1999 Safari 19 11-13-2015 01:40 PM
Globetrotter 1963 - Kitchen Sink Drain Leak Under the Floor Uncle_Phil Plumbing - Systems & Fixtures 3 08-09-2002 06:59 PM
Air conditioner drain jcanavera Furnaces, Heaters, Fireplaces & Air Conditioning 3 07-10-2002 01:52 AM
Greywater drain pipe repair davidz71 Waste Systems, Tanks & Totes 4 06-04-2002 09:39 PM
White water tank drain ramoore53 Fresh Water Systems 4 05-01-2002 10:08 AM
