Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 12-18-2017, 06:35 PM   #21
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer , Colorado
Here is a photo of the drain pipe stack on the 69 Globetrotter. It was black tank first, then the dump valve, and then the tee for the gray water drain line. I post it only so you can see some of the parts needed.
David
Name:	1703 Black Tank Drain (Small).JPG
Old 12-18-2017, 08:20 PM   #22
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Thanks!
Stephanie
Old 12-19-2017, 08:00 AM   #23
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Sounds like the installation of a gray water tank is very important to your camping style. I think that your concept is workable.
Your door opening is very small. I would plan on removing the front of the vanity and building a custom tank to maximize your gray water tank storage capacity.
Another option would be to pump the gray water to a tank that is above the sink level. Why limit yourself to gravity feed? If you force fed (filled) the tank you could locate it anywhere even in the rear of your tow vehicle.
Dan
wreck salvage...good stuff Melody Ranch General Repair Forum 5 09-18-2010 01:52 PM
LED Lights- do they wreck the vintage asthetic? SilvrSausage Lights - Interior & Exterior 36 08-31-2008 09:35 PM
Amazing video of trailer sway ending in wreck (police chase) SilvrSausage On The Road... 6 04-10-2008 07:34 AM
What would you do if you bought a wreck remcolent Off Topic Forum 33 11-13-2006 07:56 PM
I need to give a value for my wreck till Trailer Values 4 11-16-2004 06:55 PM
