Old 07-21-2014, 03:41 PM   #1
SteveH's Avatar
Common Sense , Texas
Need a Plumber's advice
Doing repairs from tire blowout damage, and glued new sewer outlet into the large "Y" outlet after grinding out the remaining piece of broken pipe. Of course couldn't get a perfect fit after the grinding, but figured the ABS glue liberally applied would seal the two pipes together, but it didn't.
What do I do now short of starting all over again with all new pipe?
Regards,
Steve
Old 07-21-2014, 03:49 PM   #2
1974 Argosy 20
Kooskia , Idaho
You may be able to use the rubber union fittings you can get at Home Depot or Lowe's. They have stainless steel clamps and fit over the pipe. Worth a look anyway, plumbing is often a lots of looking at stuff job.
Old 07-21-2014, 05:01 PM   #3
1977 Argosy 24
Milltown , Wisconsin
More glue, or make a heavy paste with abs shavings and MEK. Apply over the leak and let dry, then repeat.
ventport is offline   Reply With Quote
Old 07-21-2014, 05:05 PM   #4
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
A photo of what you are asking about might get some detailed answers.
Alan
Old 07-21-2014, 06:16 PM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I believe ABS can be welded. It's thermoplastic. Someone more skilled than I could possibly weld the new to the old. I have repaired polyethylene tanks using a plastic extruder. It melts in the 300 degree range.
If you are really ambitious, you could replace the entire dump valve manifold. It's not too expensive, just a bunch time consuming. You have to remove the big tank cover. Here is a photo of mine before and after. The ABS fittings are slip fit into the waste water tanks with a little caulk and a hose clamp. Airstream built mine that way. Reason for the project, I had leaky dump valves that needed replaced.
David
Name:	1205 New Valtera Plumbing.jpg
Old 07-21-2014, 06:46 PM   #6
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
Rough it up real good with some 36 grit sandpaper and epoxy the hell out of it.
It will stay together, and if you do a good job it wont leak.
Old 07-21-2014, 07:29 PM   #7
SteveH's Avatar
Thanks, with what little experience I have working with ABS, this does sound like the right approach.
Thinking it would work really well if I could inject this thru a tube into the void with some sort of syringe. Any ideas on that?
Regards,
Steve
Old 07-23-2014, 02:51 PM   #8
SteveH's Avatar
It seems to be fixed
Since I could see a couple of voids on the sides between the fitting and the pipe, I decided to try and fill them with ABS. I used a carpenter's hand plane to carve a couple of thin slivers of plastic off of a piece of ABS pipe I had laying around, slid them into the voids, and then applied more glue paying special attention to the void areas. Put two more coats of glue on it, let dry for a day, then tested it a while ago, and fortunately, no leaks.
Thanks for everyone's help and suggestions.
Regards,
Steve
Old 07-23-2014, 04:47 PM   #9
1976 31' Sovereign
Oswego , Illinois
Glad you got it fixed. The rubber with stainless hose clamps are called mission bands & come in many sizes, they are a great help in difficult repairs & they last in ground for many years as I have some over 35 yrs. in ground.
Old 07-23-2014, 05:48 PM   #10
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I've had the same results where they are buried. Do you have experience where the rubber fittings are exposed to UV? I used a 3" Fernco coupling to repair the ABS waste on my Safari last year. It's exposed below the belly pan.
Alan
Old 07-23-2014, 06:21 PM   #11
SteveH's Avatar
I looked for a rubber coupling, but they are all sized to fit over pipe, and I could not find one sized correctly to fit over the fittings. Everything was either too small, or too big.
I'm happy with what I did, and think it will work well long term.
Regards,
Steve
Old 07-23-2014, 08:40 PM   #12
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Wa La! Another Airstream back on the road. I imagine the adhesive "melted" the chips you forced into the voids making a solid joint.
David
Old 07-23-2014, 08:41 PM   #13
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Hope it holds up for you!
Just last week I had to do something similar to what you did, on a low pressure 1-1/4" pvc pumped waste line. Had to chip a broken pipe out of a female fitting. Not easy to do but it can be done successfully.
Alan
I'm no plumber but... riskstl Plumbing - Systems & Fixtures 3 07-12-2014 02:17 PM
Plumber's putty vs. silicone for shower pan rippie Plumbing - Systems & Fixtures 15 03-04-2014 09:32 PM
Plumber's putty or glue? cathy624 Sinks, Showers & Toilets 13 11-29-2010 05:49 PM
In search of a UK bespoke interior fitter/plumber Rachelreynol General Interior Topics 5 07-10-2008 02:51 AM
need advice re. 1969 tires, brakes, etc. Dave Cole Tires 6 01-29-2007 06:04 AM
