Old 05-29-2011, 01:26 PM   #1
Twin Lakes , Wisconsin
Need a new black water tank on the 69'... best place?
So we found a crack in the tank and it also has a major sag. So I guess we replace. Before I search the net for hours, can someone point me in the right direction? Here goes the budget....
redreefet is offline   Reply With Quote
Old 05-29-2011, 01:55 PM   #2
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Inland RV sells that tank.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 05-29-2011, 02:36 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Inland's OEM tanks are expensive, but they are very well built out of heavy fiberglass and they include the fittings for the vent and toilet flange. I figured that I would save a lot of time just buying a direct replacement rather than trying to make a cheaper generic tank fit the existing plumbing. I'd make the same choice if buying again.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 05-29-2011, 02:55 PM   #4
Lothlorian's Avatar
Loganville , Georgia
I took mine out and took pictures of it, measured it, Drew it on graph paper and sent it all to Inca Plastics. They made me a new one. I got a great deal. That was a few years ago. I will post what I sent Inca plastics. I sent pictures from all angles.
I have a thread on here about my restoration. It is long but covers how I redid my tank.
http://www.airforums.com/forums/f36/...ion-38204.html
Brian
ID:	130999   Click image for larger version
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 05-29-2011, 03:26 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I have not done it myself but the plastic tanks can be welded. I guess the question is after taking the old one out do you repair or replace.
Old 05-29-2011, 03:36 PM   #6
Lothlorian's Avatar
I am not an expert, but when I considered welding my old one I was informed the plastic used back in the early 70's would not hold a weld. I did not want to take a chance so I got a new one.
Brian
Brian & Adrienne
Old 05-29-2011, 03:57 PM   #7
The crack is in the threads where the flange goes
We do have that other Airstream that may have a good tank. But most of the stuff in the thing is pretty beat, so I'm not expecting much.
Old 06-22-2012, 02:13 PM   #8
Here it is!
It's going to require some extra welding to make it fit. We also got 2 Uniseal fittings so we could be flexible on where to install the vent & drain.
Old 06-24-2012, 10:07 AM   #9
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
Brian
Is that pic the new tank, or the original? is it an "h4" from Inca?
http://www.incaplastics.com/Airstream.pdf
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
1969 sovereign, crack, land yacht, black tank
Black water tank removal 1975 Mus289 Waste Systems, Tanks & Totes 7 04-17-2017 09:27 AM
Fresh Water Tank Size and Gauges ednspace Fresh Water Systems 4 05-23-2011 09:19 PM
2003 safari - how do you remove black water tank? greenrvlife Waste Systems, Tanks & Totes 3 04-08-2011 11:15 PM
Unable to dump black water tank before 20 deg. forecast mikeandnora Waste Systems, Tanks & Totes 3 02-04-2011 10:46 AM
replacing black water tank in 68 Tradewind clydecrashcu Waste Systems, Tanks & Totes 1 01-17-2011 10:28 PM
