Old 04-17-2013, 08:36 PM   #1
1959 24' Tradewind
Fort wayne , Indiana
Mystery leak
I recently took my 72 safari out for it's maiden voyage. When I open the waste outlet waste came pouring out like a gallon. Then after hooking up the waste line I opened the valve and the tank emptied. I can't figure where the waste is coming from. The space between the cap and the valve is small certainly not a gallons worth? Any thoughts?
Russ G is offline   Reply With Quote
Old 04-17-2013, 08:42 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Waste valve is leaking or not shut copmpletely
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 04-17-2013, 08:49 PM   #3
JFScheck's Avatar
Rockville , Maryland
Images: 33
Drain the grey tank, fill the waste tank with water and a gallon of "winterizing fluid" and leave closed for a day. If you then open that cap and you see the "winterizing fluid" you know where your leak is coming from.
If not then repeat, this time for grey tank....
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 04-17-2013, 08:59 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
It's a 72, no grey tank. This could have been grey water sitting in the pipes.
Richard
Old 04-18-2013, 06:10 AM   #5
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
A gallon is 231 cubic inches. If you have a 3" slinky, it takes 32.7 inches of slinky to hold a gallon of water. If you have a 4" slinky, it takes 18.4 inches of slinky to hold a gallon.
Then again, it's hard to estimate a gallon when it's spread out on the ground. What flowed out could have been as little as a pint, and it would still cover a large area when it's spread out in a layer less than a sixteenth of an inch thick.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 04-18-2013, 07:22 AM   #6
If the waste valve is leaking, then the material will slowly back up into the gray water pipe.
In that case, who know how much has backed up.
The easiest and cheapest way to determine the "where from" is to add some food coloring to the black water tank.
Old 04-18-2013, 09:28 AM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
What Richard said....I bet it is water from the Gray line.
