Old 02-18-2015, 01:29 PM   #1
1972 27' Overlander
Jacksonville , Florida
Mystery Black pipe questions 1972 Airstream
We are redoing our bathroom and have noticed a black pipe that runs to the ceiling and out a vent on the roof. Does anyone know if this is a custom job and what it might be used for? It splits, one end going out of the airstream with the other gray water pipes, the other running into the black water tank. We would like to get rid of it if we can.
Thanks!
ID:	232688   Click image for larger version
BARracuda is offline   Reply With Quote
Old 02-18-2015, 01:36 PM   #2
Southwestern , Ohio
That's your vent pipe. It's original, and it's needed.
Nuvite-F is offline   Reply With Quote
Old 02-18-2015, 01:53 PM   #3
King of the Zebra Speedo
Panama Red's Avatar
Obrien , Florida
Listen to Nuvite. He's dead on the money... Without that vent, toilet flushing would get interesting, and messy. For water and waste to go in the tank, the same volume of air has to come out. Right now, that air that the water and waste is replacing goes out your vent, which is conveniently outside your camper. Remove the vent, and the air will force it's way out of the toilet while waste and water try to squeeze in past it. The escaping air will blow a portion of the waste and water back into your camper, and probably on you...
Here's another tip for your vent stack. There is a rubber seal up under that little aluminum chimney that needs to be replaced every five years or so. It is a prime spot for a leak to start, and seeing as how it is leaking inside your wall, you won't notice it right away. I have three of those on my camper. They're about five bucks a pop. Cheap leak fix...
-Red, plumbing 101...
Somebody ought to clean these windows. There is a tremendous buildup of gook all over them...
Panama Red is offline   Reply With Quote
Old 02-18-2015, 08:58 PM   #4
1972 27' Overlander
Thank you very much for the information. I will look into replacing those rings.
2008 Airstream Interstate Black Water Dump Valve Installed touching exhaust pipe!! solar-guy Sprinter and B-van Forum 0 05-09-2011 10:54 AM
Why black ABS pipe? Chuck Waste Systems, Tanks & Totes 2 03-25-2005 11:09 AM
drain connections, black pipe, etc Chuck Waste Systems, Tanks & Totes 6 04-08-2004 03:45 PM
pipe between black tank and dump valve gerbermania Waste Systems, Tanks & Totes 4 10-22-2003 08:21 PM
Plumbing - A Mystery Pipe Tamara Plumbing - Systems & Fixtures 8 04-18-2003 12:56 PM
