Old 05-17-2011, 05:54 PM   #15
richinny's Avatar
2011 34' Classic
no pictures?
i guess a few bags of lime and topsoil followed by a sign saying: "do not step on the fertilized areas".
you did the best you can do in that situation.
Ricky
Old 05-17-2011, 07:34 PM   #16
Phrunes's Avatar
1978 31' Sovereign
Oakley , California
A squeegee on a stick, a bag of kitty litter with tide with bleach detergent mixed in it, a grey water hose, and you'll be set! Won't take as long to clean up so you shouldn't be too pooped when you're done.
Phrunes is offline   Reply With Quote
Old 05-17-2011, 07:59 PM   #17
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Slinky failures!
The SLINKY may be a faster dump, but those things work perfectly one moment, then develop 17 pinhole leaks in the next second, and finally rupture with no warning some indefinite time later.
The Sewer Solution is great - even for "bare handed" dumping. The trick? Start off with 2 gallons of water in the black tank, then everything else dissolves. The nice thing about newer Airstreams? The bathroom sink empties into the BLACK tank. Two gallons of black starter water? Two sinkfuls.
Paula
Old 05-17-2011, 08:05 PM   #18
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
What a horrid thing to happen! You have our sympathy, especially with a **** for brains non-Airstreamer right behind you. Still, worse things happen at sea, eh? Mind you, I'm ditching those flip flops at dump time, that's for sure!
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 05-17-2011, 08:06 PM   #19
cms4140's Avatar
Birmingham , Alabama
Good sale on these @ Camping World. Just ordered one.
Plan 9 - Sewer Solution - Drain & Flush Systems - Camping World
Not sure I will go "bare handed" though .
-Chris
cms4140 is offline   Reply With Quote
Old 05-17-2011, 08:08 PM   #20
Scott J-24's Avatar
2009 27' FB International
Los Angeles , California
I didn't know the bathroom sink emptied into the black tank. But then again, I am still a newbee! Is this true for all 'newer' Airstreams, I presume our '09 27' FB International would qualify as 'newer'. Never heard of "bare handed" dumping, doesn't sound like much fun...
Scott, Becky & Heidi (our standard poodle and travel companion)
WBCCI #1215
Air #54601
Remember... No matter where you go, there you are...
2009 27FB International Ocean Breeze
2010 Toyota Tundra CrewMax, 5.7L V8, 4x4
Scott J-24 is offline   Reply With Quote
Old 05-17-2011, 08:13 PM   #21
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
I second the endorsement of the Sewer Solution, a much nicer alternative to a slinky. Order the 10 foot extra hose right away. We got caught at a site with the dump too far away to reach with the stock hose. Had to revert to slinky. Not fun.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 05-17-2011, 08:15 PM   #22
cms4140's Avatar
Is the extra hose easily connected?
-Chris
Old 05-17-2011, 08:19 PM   #23
MrUKToad's Avatar
Chatham , Ontario
Fine where you have a sewer hookup but not sure how that'd work work when you have to use the site's communal dump station, though. The last two dump stations I used had no water available for us to even use the tank flush!
Old 05-17-2011, 08:35 PM   #24
2011 31' Classic
-Chris
Yep, just a twist and a turn and a push. Done.
Old 05-17-2011, 08:36 PM   #25
2011 31' Classic
Too true. I still carry the slinky for just such situations. Had one last trip. Good point.
Old 05-17-2011, 08:43 PM   #26
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Oh, that made me laugh! It's everyone's nightmare at the dumpstation. Especially while other people are waiting/watching! I'm anal (pun intended) about my tanks rinsing clean (I use a flush king & can see everything) and am always a wreck cause people always seem to be waiting for me. I can see why you are having nightmares! Yeah, I'd ditch the flip flops too! Eeww! And Ha! Thanks for the laugh!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 05-17-2011, 09:19 PM   #27
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I just watched the video for the Sewer Solution and have some concern for those that do not have a tank flush system to assist with removal of solids. The rapid movement of liquids is necessary to remove the solids at the bottom of the black tank. With the reduced flow rate, how does this Sewer Solution overcome this?
Old 05-17-2011, 09:31 PM   #28
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Some, but not all newer Airstreams are plumbed this way. Our bathroom sink empties into the grey water tank...not the black water. You can find out where yours empties by testing it. When your tanks are completely empty, close both dump valves. Fill the bathroom sink with water a couple of times, letting it drain. Then open the dump valves one at a time. The one that has the water in it is where your bathroom sink goes.
TB & Greg and Abbey Schnauzer
#3954
Some insight on how things end up the way they are Boondocker WBCCI Forum 24 04-26-2011 08:06 PM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
