Old 10-23-2005, 10:40 AM   #1
SqurlGurl
squrlgurl's Avatar
1977 31' Excella 500
Bozman , Maryland
"Must-Have" suggestions for potty area
We have our black tank out of the trailer to do some floor repair. When it goes back in we don't want to have to deal with it for a long long time so here's my question...
After reading through the forum and seeing all kinds of tweaks and upgrades to the tank/toilet/sewer outlet/plumbing/etc systems I am a bit overwhelmed as to what may be the "must-haves". What are the best installs or upgrades that make life easier in the future?
So far the list is:
-Replace sewer valve
-Reinforce fiberglass tank
-Repaint Tank Facing (ours sits above the floor)
-Remove wood facing on walls around toilet and replace with something more sanitary and easier to clean (Poly or fiberglass sheeting?)
- New toilet
- New grey water and vent plumbing
I am thinking about installing a heater mat under the black tank (we live in the Mid-Atlantic with cold winters) and possibly heat-wrap around plumbing elbows.
Thanks!
-Tracey
WBCCI# 7794
(\__/) (((( ))))
/O O ./ ((( ))))
{O__, \ (( )))
.( _( )_.'
'---.~_ _
squrlgurl is offline   Reply With Quote
Old 10-23-2005, 11:30 AM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Thanks!
-Tracey
Tracey,
Your black tank is heated by the furnace. You should have a heat register right in front of the toilet area, which has a provision to circulate heated air around the black tank.
Which makes updating the plumbing at and around the black tank an even better idea. Imagine a tiny leak from teh black tank, and then the hot air circulating the odor into the trailer. Eeeww!
I further suggest to update the dump valve flange, so that a modern dump valve can be fitted. I did not follow your links above, you might have this one already taken into consideration.
But then, since you're already almost there, why not add a grey tank, at least a small one to enable having a shower or washing up while underway?
Uwe
www.area63productions.com
Old 10-23-2005, 05:25 PM   #3
tyndalelady's Avatar
Prescott Valley , Arizona
Add a tank flush if you can. They screw into the tank and you can flush it out with a hose from the outside. Depending on where the tank is this would be a wonderful addition.
1983 Excella 31 - Sold
2001 Dodge 2500 V10 - Sold
Looking for a new rig and tow vehicle.
tyndalelady is offline   Reply With Quote
Old 10-23-2005, 08:18 PM   #4
SqurlGurl
squrlgurl's Avatar
Bozman , Maryland
Uwe, We are plannig on using a catalytic heater for awhile. The old furnace needs to go, so we won't have the hot air circulation to benefit from at least for now. The floor in the bathroom was rotten around where some part of the toilet had seeped into the wood over the years. ANd you are right...when we put a small space heater in the trailer and began working back there...well...it was a bit nasty! Take a look at my link (picture of my dump valve ass'y) and let me know if you have seen that type still in use. I am assuming it will need to go and that newer fittings will not be compatible with it.
tyndalelady, I can remember my grandparents going through the routine of flushing their black tank in their RV with a hose from the outside and how inconvenient it seemed. So a built-in tank flush is a great idea! Thanks.
-Tracey
WBCCI# 7794
(\__/) (((( ))))
/O O ./ ((( ))))
{O__, \ (( )))
.( _( )_.'
'---.~_ _
Old 10-23-2005, 08:45 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
After reading through the forum and seeing all kinds of tweaks and upgrades to the tank/toilet/sewer outlet/plumbing/etc systems I am a bit overwhelmed as to what may be the "must-haves". What are the best installs or upgrades that make life easier in the future? ... -Tracey
Wellll, speaking only from the perspective of owning our 67, I would, if doing a toilet makeover, add a TP holder that actually works.
Lyn
WBCCI 21043
Old 10-24-2005, 09:13 AM   #6
SqurlGurl
squrlgurl's Avatar
Bozman , Maryland
Lyn, Is your TP holder the one with the gigantic spring to hold the roll? We haven't donned ours with a roll yet but now that you mention it, it does look a bit odd. Even though it is positioned right where you'd need it to the left of the bowl, it still seems to be in the wrong spot. And our toothbrush holder *right over* the toilet seems a bit of poor engineering as well. All I can imagine is *something* going wrong with the loo (saw the phrase "tower of terror" in another post) and having a mess to deal with directly behind where I sleep and eat is not my idea of a good vacation.
Call me OCD, but I want to have the toilet area as easy to sanitize as possible, and will probably be cleaning it obsessively.
Our VW camper has no toilet facilities so the AS will be my first experience with my own mobile potty.
WBCCI# 7794
(\__/) (((( ))))
/O O ./ ((( ))))
{O__, \ (( )))
.( _( )_.'
'---.~_ _
frig and a/c suggestions Neenm General Appliance Topics 6 04-08-2007 07:42 PM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
Good campground in Omaha NE area? 83Excella On The Road... 0 07-24-2002 09:01 PM
Quebec campground suggestions rdm On The Road... 1 07-14-2002 04:34 AM
Ideas, suggestions, needs? ALANSD Forum Admin, News and Member Account Info 5 06-22-2002 09:21 PM
