Old 12-03-2008, 12:40 PM   #1
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
Mud flaps
Has anyone added mud flaps to their AS - especially on the side with the dump valves? I read about someone whose tires threw a rock into the dump valve assembly and made a horrible mess out of the assembly.
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 12-03-2008, 01:35 PM   #2
1994 30' Excella
Mississauga , Ontario
I have never seen a trailer with them but it seems like a reasonable idea even if all it does is keep the dump valve handles and pipe cap clean of mud.
Al
Old 12-03-2008, 04:08 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I've considered it. It would be fairly easy given that an outrigger is right there at the back of the rear wheel well. I would think some good caulk and some self tapping screws could do the trick fairly painlessly and safely without allowing moisture to get into and beyond the outrigger, rusting/rotting it and the surrounding areas.
Old 12-03-2008, 04:26 PM   #4
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Sounds like a great idea. All that stuff looks really vulnerable to me.
Reminds me of the idea of wrapping all the propane lines under the trailer with a covering—I imagine any kind of flexible tubing slit horizontally would work—hose clamps could hold it in place.
Gene
mud flaps beercan Trailer Values 7 04-07-2008 09:14 PM
Mud flaps on a AS? AirHog Rock Guards, Segment & Window Protectors 8 04-29-2005 11:42 AM
Mud flaps on a AS? AirHog 2004 Safari 0 04-05-2004 07:07 PM
Mud flaps on an A/S Silvertwinkie Our Community 8 03-10-2003 06:29 AM
Mud flaps on an A/S MH ALANSD Airstream Motorhome Forums 3 03-10-2003 05:58 AM
