Old 02-26-2010, 06:16 PM   #1
1970 23' Safari
Ventura , California
moving waste tank 67 overlander international
I am completely remodeling my 1967 overlander international and really want to move my bathroom to the middle and put a double bed in the back. (We usually camp with my husbands huge family and I like my privacy.) Does anyone know if the waste tank would fit near the axl?
jaminalee is offline   Reply With Quote
Old 02-26-2010, 06:28 PM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
That black water tank will not fit in any other place then where it sits with the stock frame. Airstream made that area extra wide to accommodate the tank. This does not mean that you cannot do the conversion. You will just have to work a new tank system and while you're moving things around you can add a gray water tank too.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 02-26-2010, 09:14 PM   #3
1970 23' Safari
When you say I will have to work a new tank system do you mean that I should get new size tanks that will fit in between the frame? If I do that I could split it up by adding a gray water tank AND black one? which in turn will accommodate two smaller tanks...
Heating Waste Tank Cracker Winter Living 4 09-23-2009 02:46 PM
waste tank source batt Waste Systems, Tanks & Totes 4 09-19-2009 08:42 AM
Polyethylene Waste Tank -Typer Waste Systems, Tanks & Totes 0 02-10-2009 12:07 PM
Moving my 31' International 100 miles or so chasrahm Hitches, Couplers & Balls 6 01-09-2009 04:43 PM
Waste tank aeration tmcdougald Waste Systems, Tanks & Totes 2 07-21-2005 06:43 PM
