Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Plumbing - Systems & Fixtures > Waste Systems, Tanks & Totes
Old 12-03-2004, 11:38 AM   #1
Stefrobrts
Stefrobrts's Avatar
Profile:  1968 17' Caravel
Battle Ground , Washington
Moving sewage outlet?
The black tank outlet on our trailer is located directly under the toilet, putting it about two feet under the trailer, pointing straight down. When it's time to hook up to it, you almost have to get on your knees to reach it, which is not a pleasant idea at most dump stations. Seems like I've seen new trailers with connections on the side of the trailer, where it would be much easier to hook up to. Has anyone rerouted or redirected their vintage outlet to make it easier to access?
Stephanie
Our family photo blog
Old 12-03-2004, 01:07 PM   #2
markdoane
Profile:  , Minnesota
Images: 59
If you are taking off the belly pan, you can install a tee, with a macerator pump mounted on the side of the tee. It is easy to run 3/4" line from the macerator pump out to the side, and not have a lot of stuff hanging down. You would need a 12v power line to run the pump.
Non-contributing deadbeat.
Old 12-03-2004, 08:00 PM   #3
malconium
Profile:  1973 31' Sovereign
Portland , Oregon
Macerator pump could be below the belly pan too...
Stephanie,
I am intending to add a macerator pump to my AS (when I finally get to that point). It will need to mount below the belly pan with the way that my holding tank works. There is a unit available at the RV Parts Outlet store in Tualatin, OR for $152.95 that has my attention. In your case you could just install an elbow onto the bottom of your holding tank and mount the macerator horizontally. It would hang done slightly more than 3" total. The small hose would connect to the side of the pump and could easily be routed to any convenient place. It would also be a lot easiet to connect at the campsite than the 3" line if you wanted to do it then.
https://www.rvpartsoutlet.com/newsto...2FFF6A2A68EB32
Malcolm
malconium is offline   Reply With Quote
Old 12-03-2004, 08:14 PM   #4
till
till's Avatar
Profile:  1967 26' Overlander
1968 26' Overlander
Lisle , Illinois
Images: 108
Stephanie,
I plan on doing the same thing. You may have to cut a hole in the frame to route it out though. That is part of my master plan. Basicly just mount a 90 on the dump valve and a short section of pipe that goes through that frame with the proper cap and connector for dumping.
Tedd Ill
AIR#3788, WBCCI#4028
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 12-03-2004, 09:45 PM   #5
Stefrobrts
Stefrobrts's Avatar
Since this is our first RV, macerator pumps are a new topic to me. I'll have to read up on them a bit. I assume you can still use the 3 inch hose, since that seems to be the size all the campground hookups are set up for? Does it slow down dumping a lot? In our system grey water runs out through the 3 inch hose while at the campsite (no grey tank, though I'd like to fix that someday to make boondocking a little simpler), is that a problem if I add one of these pumps?
Stephanie
Old 12-03-2004, 10:02 PM   #6
markdoane
Images: 59
The advantage of a macerator pump is that you can use a 3/4" hose (just stick it down the hole) instead of dragging around a 3" hose. Also, it can pump uphill if that is required. You could also attach the 3/4" hose to an adapter on your 3" greywater hose, if you want to leave the 3" graywater hose hooked up to the campground hookup. There are really a lot of options how to use it.
If you decide to do this, I would use a tee mounted vertically on your tank outlet, with a regular valve and 3" cap pointed down, and the macerator pump mounted on the side outlet of the tee. That way you have a way to empty the tank if the pump malfunctions.
I mounted a new greywater tank forward of the axle, with a 3" outlet. By using a macerator pump, I was able to co-locate the macerator pump outlet with the grey tank outlet, just forward of the streetside wheelwell.
Old 12-04-2004, 08:58 AM   #7
eubank
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
Ya know, my dad installed a swimming pool vacuum hose instead of an RV hose to dump his rig (a 5th wheel). He just makes sure that he uses a liquifying-type chemical in the black tank.
Lynn
WBCCI 21043
Lynn's blogsite: http://forum.aardvarkrv.com/blog/
If you're WBCCI, come visit us at the park (and get more cool air and less oxygen and ... a 50% discount!)
Old 12-04-2004, 10:20 AM   #8
Janet's Husband
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
Question Problem?
I have a few questions about macerator pumps and the wisdom of using them.
What do you do when the pump does not grind the gunk?
How long will one last, without repairs or cleaning?
What is the recommended maintenace?
I for one really like simple, and Gravity works without maintenance.
The dump valves are common to both systems so I won't consider them as an extra point of failure.
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 12-04-2004, 11:08 AM   #9
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 144
In reply to Gary's Questions
Originally Posted by Janet's Husband
What do you do when the pump does not grind the gunk?.
I tee'ed into the line between the dump valves and the discharge outlet (see White 3" tee below). If the Macerator fails, use the original dump system as prior to Macerator installation. - the only change to the original system is the installation of the 3 X 3 X 1 1/2 tee. I have not yet had it fail to pump, and it has had some pretty serious "loads" through it. I always pump the black tank first, allowing the gray water to "flush" the pump. - I would suppose that if a huge amount of solids were to hang up at the pump the head of grey water would tend to dilute them.
How long will one last, without repairs or cleaning?.
I have a friend who has had one installed on his boat for 5 years (salt water application) and is still in service.
What is the recommended maintenace?.
I don't recall that any service was recommended - there is a replacable rubber impeller - note that due to the impeller the pump will not allow water to "free flow" through the pump. The motor has to be running for any appreciable amount of fluid to pass.
I for one really like simple, and Gravity works without maintenance..
Yeah, but the Macerator pump makes things SO EASY - and clean too. - One of the best mods I installed on the MoHo. It dumps quicker, easier to clean up (I have half unions on all connections), and NO chance of a 3" hose slipping off - yuck.
IF you have to service a kump valve, install the Tee with the 1 1/2" leg plugged off. You never know when you will "warm up" to the idea of a Macerator.
Below are pics of the 12 gpm Jabsco pump installed on the 345.
Name:	Discharge Piping.JPG
ID:	9642  Click image for larger version
Name:	After Modification.JPG
Dennis
WBCCI # 1113
AirForums #1737
Old 12-08-2004, 08:09 PM   #10
malconium
Portland , Oregon
A brainstorm about macerator location...
I had been thinking that I would need to install my macerator pump below the belly pan because the new combined grey/black tank I intend to install will hang down below the belly pan by about 4". I was trying to get the pump as close to the bottom of the tank as possible. What suddenly occurred to me was that maybe the pump does not need to be as low as possible - just the pick up point. That got me to thinking about how I could mount the pump inside of the belly pan again.
So here is a proposal that I would like some feedback on...
1.) I would mount the pump inside of the belly pan and centered between the belly pan and floor.
2.) I would create some sort of elbow shaped 3" pipe that I would try to insert inside of the new tank. One end would connect to the side of the tank toward the macerator pump and the other end would rest on the bottom of the tank. I realize this would reduce the volume of the tank some but I am OK with that I think.
3.) I would cut away most of the bottom end of the elbow leaving small feet to support it a constant distance away from the bottom of the tank. I am thinking that the openings would be about 1" tall from the bottom of the tank.
4.) I would connect the macerator pump to the elbow from outside of the tank. My connection would pass through one of the holes in the cross-member that would be between the pump and the tank.
So does a macerator pump have enough suction to be able to work in a position where it is centered at a point maybe 6" above the floor of the tank?
What do you think?
Malcolm
Old 12-09-2004, 05:48 AM   #11
87MH
87MH's Avatar
Images: 144
Originally Posted by malconium
So does a macerator pump have enough suction to be able to work in a position where it is centered at a point maybe 6" above the floor of the tank? What do you think?
The Jabsco Macerator is "supposed" to be self priming to four feet ....however......while your pump mount description above should be fine for a gray water tank, I would think that the pump would have a difficult time picking up any solids at all through the 3" ell (no velocity in a 3" line to "lift" the solids). Remember the solids (both the toilet paper and the "other" stuff) must flow as a plastic until they hit the macerator blades where they are ground up into little bitty pieces that are then held in a suspension in the water and can be "pumped" like water. Also, as you indicated, when the water level in the tank is drawn down to the top of the cutout in your 3" ell , suction to the pump will be lost (air will be drawn into the pump) and the bottom 1 inch of fluid in the tank will not be able to be pumped out.
The description of your proposed combination gray/black tank plumbing sounds more like a true septic tank than a holding tank. I would be afraid that the solids would take quite a while to dissolve naturally (via biodegradation) to the point that they could be held in suspension and be pumped (pulled up with the water through the low velocity suction line), also I think that the cut outs (inlets) in the 3" ell would be low velocity choke points to the inlet of the pump, and would have a high likelihood of "packing off" with the "plastic solids".
So, in my opinion, I would have to say that your proposed plumbing arrangement would have a high likely hood of operational failure due to loss of suction or solids packing off somewhere in the suction line.
I might offer this as an alternate proposal...the bottom of the tank has already been established as the "low point" of the installation...install a 3" line horizontally into the tank where you want to dump from (a conventional 3" dump arrangement), install your valve onto this line, and install plumbing similar to my set up as pictured above (3" X 3" X 1 1/2" Tee). If the pump fails for any reason I have the conventional dump system as a back up. By taking the suction to the macerator from the downward facing leg of the tee the pump suction is assured of being flooded at all times (it will "suck" the tank dry). If you will note in my installation, the sections of the plumbing that are closest to the road, and subject to collateral damage, are all rubber or flexible PVC hose - the thinking was that these are sacrificial connections - easily reattachable or replaceable if damaged. One thing I should change if I have to work on the pump - the outlet of the pump in the last picture above is pointed "down" toward the road....the pump head is "clockable" in 90 degree increments - I believe if I turn the outlet 90 degrees (horizontal instead of vertical) it would be exposed to fewer road hazards.
In over a year of use (and over some really nasty gravel roads in Missouri) everything is still secure.
Good luck - I'm looking forward to pictures of your solution.
Dennis
WBCCI # 1113
AirForums #1737
Old 12-09-2004, 07:24 AM   #12
74Argosy24MH
Profile:  LOST , Hawaii
Go to Phred's site, way down near the the bottom of the page is a diagram for hookup and the maintenance requirements.
He shows a bypass system in case of problems. He also says they do plug and need to be torn down yearly to be cleaned and to prevent damage. I read this a few years ago and also decided gravity works. You are still handling a sewer hose, but you are adding another item to maintain and a nasty one at that.
John
74Argosy24MH is offline   Reply With Quote
Old 12-09-2004, 11:51 AM   #13
Stefrobrts
Stefrobrts's Avatar
Dennis, your sig seems all the more appropriate considering the topic...
Stephanie
Old 12-09-2004, 03:08 PM   #14
malconium
Portland , Oregon
Dennis,
I appreciate your comments and suggestions. I had originally been thinking of an arrangement similar to what is in the attached sketch - except without the T between the macerator and the dump valve. Does this seem like a better overall approach? I notice that your assembly uses a 1-1/2" connection to the macerator. Do you think there is any advantage one way or the other for 1-1/2" vs 3"? The standard macerator pump I am looking at comes with the 3" connection and the pump body itself is pretty much the same diameter. Perhaps this approach would still not put the pickup point for the "plastics" low enough. What do you think?
Part of the reasoning for using a combined gray/black tank was that the extra water would help keep the solids in suspension and might help break them up better. Again what do you think?
Malcolm
Rear TV Antenna Outlet lbrodsky 2001 Safari 11 12-15-2002 02:37 AM
AC Outlet Analyser Les Gilliam Electrical - Systems, Generators, Batteries & Solar 9 11-15-2002 08:04 AM
Help!! exterior outlet cover stuck DIMMER Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 11:04 AM
Waste Water Outlet Valves Danno Waste Systems, Tanks & Totes 2 06-18-2002 10:48 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
Powered by vBadvance
