Old 04-20-2010, 08:33 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
minuet dump extension?
I'm helping my daughter out with her 1977 Minuet 6 metre. Her dump tube is so far under the trailer that you practically have to crawl under there to attach the slinky. She doesn't want to do that at a dump station (neither would I!). Has anyone with a Minuet put an extension on their tube? If so, where did you get it & what did you get? Thanks in advance (like I don't have enough projects of my own to do!)
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 04-21-2010, 05:11 AM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Becky!
I don't know that there is a good solution to the dump termination on the Minuet. Unless the trailer has a new axle with a much larger than stock down angle, any form of extension is going to be exposed to damage if it is left on the coach during travel. Even with a new axle, I have had to have my dump valve rebuilt twice following incidents where it was drug on the road while crossing a drainage channel at an intersection.
When towing my Minuet, I always carry a 4' x 4' rubber mat and heavy duty rubber gloves to use when dumping the Minuet's waste tanks. It isn't the best solution, but I have found that it works acceptably under most circumstances. I have also found that it becomes easier to connect the dump hose to the fitting the more one uses the coach.
Good luck with your project!
Kevin
Kevin D. Allen
AIR #827
Old 04-21-2010, 05:17 AM   #3
Baltimore , Maryland
If you stretch a string from the bottom of the tire back to the bottom of the bumper you should find the safe zone. It is very hard for anything to be damaged within that triangle. I would not let anything hang down below that.
Old 04-21-2010, 01:20 PM   #4
Becky B.'s Avatar
1964 17' Bambi II
Thanks for the advise. I'll pass it along to her. At least she's young & limber!
Becky
1964 Bambi II
1988 Avion 32S
Hitch Extension???? Drathaar Hitches, Couplers & Balls 16 09-16-2009 09:28 PM
Extension Cable Size IrishRover2 General Repair Forum 13 01-16-2008 12:23 PM
Step Extension Storage Ganglin Steps 3 10-01-2007 09:52 AM
Hitch extension Phil Gobie Hitches, Couplers & Balls 26 12-05-2006 02:54 PM
Receiver Extension bugdoc 1997 - 2004 Bambi 10 11-17-2004 04:41 PM
