Old 09-18-2016, 04:10 PM   #1
LizGK's Avatar
2008 31' Classic
Rochester , New York
Micropulse - Why did black and grey monitors just quit?
I hope I'm posting in the correct forum....
Last evening our black and grey tank monitors ceased to work - at the same time. They've been fine for the last 2 weeks and now, kaput. We checked the connection in the Micropulse and all connections are solid. Looks like the other end of the connections are in the belly pan - which we can't get to.
What would be the diagnostic for both of these system to not register simultaneously?
We arrived 2 days ago (in a state park) with a full fresh water tank, and empty black and grey. We are confident they are both almost empty.
Thanks in advance,
LizGK is offline   Reply With Quote
Old 09-18-2016, 05:47 PM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
If you put the Micropulse in monitor mode do the the grey and black tanks show green? With the panel turned off press the power and status buttons at the same time. All lights should turn green. Then press the status button once. The three tanks should show green. If any are yellow then the sensor is defective or there is a bad connection.
On my 2008 Classic 25fb under the fridge where the water pump is located the monitor sensor wires come up from the tanks and the sensor wire from the panel are joined together with a RJ-11 connector. This allows the tank sensors to be disconnected without cutting the wires. The sensors on the tanks are located close to the dump valves of the waste tanks and the drain of the water tank which in my case is on the street side of the trailer. The monitor panel is located on the curb kitchen wall. The wires are run under the subfloor via the subfloor chase.
When I calibrate my tanks I usually disconnect the tanks I don't want calibrated. One tank will go crazy occasionally. Recalibration seems to correct it for the season. I use an inline water meter to measure how much water I put in the tank for the empty and full readings.
Replacing black/grey with a larger grey whitney Waste Systems, Tanks & Totes 11 05-08-2012 06:47 PM
MicroPulse black tank sensor PhiDor Waste Systems, Tanks & Totes 16 12-22-2011 03:54 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
Why aren't the grey and black holding tanks one? Kistler Waste Systems, Tanks & Totes 26 06-02-2004 03:41 PM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
