Old 11-02-2011, 05:32 PM   #1
PhiDor's Avatar
2007 34' Classic S/O
The Villages , Florida
MicroPulse black tank sensor
I am about embark on changing the black tank sensor on my 2007 34' Classic.
Can someone tell me where it is located specifically? How do I know I am not changing the wrong sensor, other than the ODOR?
Thanks.
Phil & Doris Drugge
[COLOR="Red"]WBCCI #4941
"Jerry and our Amazing Dream Stream"
PhiDor is offline   Reply With Quote
Old 11-02-2011, 05:45 PM   #2
dznf0g's Avatar
Oswego , Illinois
I think your tank layout is the same as mine, even though mine is a 30'. Under the wardrobe floor, through the cutout on the floor for the fresh water line...if you look aft a little you should see the black tank sensor. It'll be a little difficult for you to bend yourself to get at it, but it's better than the gray tank sensor.
-Rich-
Old 11-02-2011, 06:29 PM   #3
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
It threads into a fitting either on the side of the tank against the bottom, or it might be in a fitting along the bottom of the drain pipe between the tank and the dump valve. The cable going to it plugs in like a phone plug. If you can see the cable, maybe you can follow it down to its location. I've never looked for mine, just assumed I would have to drop the pan to get to it. If that sensor is giving you trouble you might try to replugging the cable into it for a better connection before replacing the sensor.
AIR 47751
Silver Goose is offline   Reply With Quote
Old 11-02-2011, 06:38 PM   #4
ctdair's Avatar
Changed fresh water sensor from inside wardrobe and didn't see any other sensors. To calibrate rather than filling tank for full level I got the tank dimensions from Airstream and built a pvc pipe with threaded nipple. The height of the pvc above the sensor is the same as the tank depth. With only several ounces of water You can calibrate the full level versus gallons. These sensors work on head pressure and it is constant over depth regardless of the diameter or overall volume.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch.
Pulled by a 2019 F350 Superduty Limited.
ctdair is offline   Reply With Quote
Old 11-02-2011, 06:45 PM   #5
10Smiles's Avatar
2005 30' Classic
Kingston , Washington
Very nifty trick for calibrating. I'm impressed.
10Smiles is offline   Reply With Quote
Old 11-02-2011, 08:43 PM   #6
2008 27' Classic FB
Burkburnett , Texas
That is a great solution for calibrating the sensor. Thanks.
AIR 47751
Old 11-03-2011, 03:42 AM   #7
ctdair's Avatar
After I calibrated the sensor that way I mentioned it to Don while on a tour of the factory and he showed me the tubes the factory used to do the same thing.
Head pressure was something we learned in Millwright school.
S/OS #010
Old 11-04-2011, 07:37 AM   #8
PhiDor's Avatar
Hi,
Can you post a picture of that pipe? Dimensions?
Phil & Doris Drugge
Old 11-04-2011, 09:33 AM   #9
Weldon Spring , Missouri
I'll welcome any shortcut to the calibration procedure....now if they'll just improve the reliability of the sensors themselves....
fmr.capt.evi is offline   Reply With Quote
Old 11-04-2011, 11:43 AM   #10
2008 16' Safari
Destrehan , Louisiana
Don't waste your time with this. I've changed and calibrated my black water sensor three times. It still does not work. The grey water and freash water seem to work fine. Just look down the toilet to check the level.
There have been several post about the MicroPulse level gauges. Nobody seems to have any luck with them Try digging through the old post about this.
dlb435 is offline   Reply With Quote
Old 11-04-2011, 04:41 PM   #11
ctdair's Avatar
Didn't save the dimensions , guess I should have in case sensor fails again. Airstream was very helpful in sending tank dimensions(Blueprint cad drawing) by email in pdf form. To make the pipe it was just a pvc elbow with the correct heighth pipe glued in one end and the correct adapter for the pipe thread of the sensor glued in the other elbow end. Carry the pipe to the trailer plug in the sensor and calibrate per micro-pulses instructions. It only takes several ounces of water then versus filling complete tank.Guess I should have saved the pipe ,I probally did that but where it is at escapes me at the moment.
S/OS #010
Old 11-04-2011, 04:49 PM   #12
dznf0g's Avatar
Oswego , Illinois
Over the first year of ownership, and many tries, I think I have discovered something. I believe it takes a considerable amount of time for the sensors to equalize with changes in pressure.
After several attempts to calibrate in rapid successions, I gave up. I began to notice while camping that rapid "dumps" into the gray tank were not readily reflected in the monitor level lights. So this spring I decided to try a calibration again.
In the first step, allow the tanks to be empty for several hours. Then start he process. Perform the "empty" readings. Fill the tanks JUST LIKE THE INSTRUCTIONS SAY VERBATIM! That means, Fill them, then drain a little, so you have warning before they are truly full.
LET THEM SIT AT THIAS FULL LEVEL FOR SEVERAL HOURS!!!!!!!!!!!!!!
Then proceed with the "teaching" the monitor the full level. Don't worry, apparently the monitor will stay in calibration mode indefinitely
-Rich-
Old 11-05-2011, 10:04 AM   #13
Hi dznf0g, I'm looking forward to trying your new "procedure".....come to think of it, in the past I have noticed brief time lags in the reporting of rapid level changes, (especially when liquid is ADDED to the tanks), so it makes complete sense that the sensors would behave like that in calibration mode, too. I failed to connect those dots.
However, assuming that a satisfactory calibration really takes several hours to achieve, now I'm even MORE disappointed with Caton Products, and Airstream, too. (SEVERAL HOURS?? PLEASE, AIRSTREAM!!??)
Old 11-06-2011, 07:17 AM   #14
dznf0g's Avatar
Oswego , Illinois
I don't KNOW that it takes several hours to "settle" in....I just waited that long cause I didn't want to do it again.
-Rich-
Old 11-07-2011, 08:22 AM   #15
2005 28' International CCD
San Jose via Winnepeg, Toronto, Orlando, Saratoga and Groton , California
Send a message via AIM to tyggeln Send a message via MSN to tyggeln Send a message via Yahoo to tyggeln
I think mine has been in calibration mode for over two years. Perhaps I'll finally calibrate the monitor again with the tube setup.
Chris
2005 28' CCD International
2x120W Solar Panels/22A GoPower Controller
1200# Equalizer Hitch
2007 GMC Yukon XL SLT
"Where are my keys?"
tyggeln is offline   Reply With Quote
Old 12-20-2011, 04:15 PM   #16
ctdair's Avatar
Found the tube I made for this procedure. Will post pic and dimensions , but will be Thursday before I have a chance. I made it out of copper ,thought I had used pvc but I must have had the right fitting in copper.
S/OS #010
Old 12-22-2011, 03:54 PM   #17
ctdair's Avatar
http://www.airforums.com/forums/f443...7fb-85787.html
Posted picture of tube and dimensions in above thread.
S/OS #010
Black water tank valve flange Safari64 Waste Systems, Tanks & Totes 1 09-22-2011 07:50 AM
Tank Level Sensor - Just Learned Something AirsDream Plumbing - Systems & Fixtures 3 06-26-2011 04:15 PM
No black tank in 62 Tradewind tlsmit1 Waste Systems, Tanks & Totes 1 05-15-2011 04:53 PM
New Slant on Tank Sensor Cleaning... Mexray Waste Systems, Tanks & Totes 5 01-30-2011 01:07 PM
